newuser-cb9e0645-ad5c-4a6b-b58c-af6aec42b549 avatar image
Error code: license_generate_challenge_failure
How to fix this error code on a 4k Firestick
fire tv
newuser-f1ac96a5-2533-417a-94d4-d125e379ba38 avatar image
newuser-f1ac96a5-2533-417a-94d4-d125e379ba38 answered
If you are running a VPN on your Fire TV or Fire Stick, temporarily turn off the "autoconnect"/ "connect at boot/start-up" feature in your VPN and reboot your device.
Make sure you can play any Prime video again without getting the error, and then turn back on the "connect at boot/start-up" feature in your VPN.
Once again confirm you are still able to play Prime video content.
There is also this procedure for devices not running a VPN:
https://forums.tomsguide.com/faq/how-to-fix-amazon-fire-tv-license-error.435366/
Mike@Amazon avatar image
Mike@Amazon answered
This forum is for Amazon Developers.
Please use the Amazon Digital and Device forum for this and similar questions.
You can also contact Amazon Customer Service.
Thanks,
Mike
