kushalc avatar image
kushalc asked
Mode Controller not working
I am getting "I don't know how to set Light to that Setting." while setting the scene/mode using message "set light scene to normal". Discovery is working well and I can even see the modes "normal" and "presentation" on alexa app for "light" device. When I click normal on alexa app, it does call the lambda function with proper request. But not working through voice request on echo. Power on/off is working from everywhere. Can someone help with mode controller.
Here is the payload json from discovery response.
            "endpoints":
                    "endpointId": "light",
                    "manufacturerName": "Test",
                    "friendlyName": "Light",
                    "description": "Test Light Zone",
                    "displayCategories": ["LIGHT"],
                    "cookie":{},
                    "capabilities":
                          "type": "AlexaInterface",
                          "interface": "Alexa",
                          "version": "3"
                            "interface": "Alexa.PowerController",
                            "version": "3",
                            "properties": {
                                "supported": [{
                                    "name": "powerState"
                                 "retrievable": true
                            "interface": "Alexa.ModeController",
                            "instance": "Light.SceneMode",
                            "version": "3",
                            "properties": {
                                "supported": [
                                    "name": "mode"
                                "retrievable": true,
                                "proactivelyReported": true,
                                "nonControllable": false
                            "capabilityResources": {
                                "friendlyNames": [
                                    "@type": "text",
                                    "value": {
                                      "text": "scene",
                                      "locale": "en-US"
                                    "@type": "text",
                                    "value": {
                                      "text": "mode",
                                      "locale": "en-US"
                            "configuration": {
                                "ordered": false,
                                "supportedModes": [
                                        "value": "SceneMode.Normal",
                                        "modeResources": {
                                          "friendlyNames": [
                                              "@type": "text",
                                              "value": {
                                                "text": "normal",
                                                "locale": "en-US"
                                              "@type": "text",
                                              "value": {
                                                "text": "regular",
                                                "locale": "en-US"
                                        "value": "SceneMode.Presentation",
                                        "modeResources": {
                                          "friendlyNames": [
                                              "@type": "text",
                                              "value": {
                                                "text": "presentation",
                                                "locale": "en-US"
                                              "@type": "text",
                                              "value": {
                                                "text": "projector",
                                                "locale": "en-US"
alexa smart home
3 comments
Any inputs?
Any inputs?
Still stuck with no idea how to solve this?
kushalc answered
I figured out the issue. It was locale. My setup was for en-IN and I used en-US as part of discovery response. Changing it to en-IN resolved the issue for me.
Thank you. Yes it was the language locale settings for me too. I changed from en-UK to en-GB and things started working for me
kushalc answered
KirkC@Amazon avatar image
KirkC@Amazon answered
Hi. I only see a few minor issues:
  • The JSON posted ends with a semi-colon, which is odd and invalid JSON.
  • The JSON posted is missing the entire "event" object.
  • The JSON posted is missing the "payload" object which encapsulates the "endpoints" array.
After making these changes, I was able to use your JSON to successfully discover the light. Please see the following full Discover.Response JSON that my test skill generated.
   "event": {
      "header": {
         "namespace": "Alexa.Discovery",
         "name": "Discover.Response",
         "payloadVersion": "3",
         "messageId": "0d17ccb1-de66-494c-807d-4f2b56634ffd"
      "payload": {
         "endpoints": [
               "friendlyName": "Forum Light",
                  "LIGHT"
               "cookie": {},
               "capabilities": [
                     "version": "3"
                     "version": "3",
                     "properties": {
                        "supported": [
                        "retrievable": true
                     "version": "3",
                     "properties": {
                        "supported": [
                              "name": "mode"
                        "friendlyNames": [
                              "@type": "text",
                              "value": {
                                 "text": "scene",
                                 "locale": "en-US"
                              "@type": "text",
                              "value": {
                                 "text": "mode",
                                 "locale": "en-US"
                     "configuration": {
                        "ordered": false,
                        "supportedModes": [
                              "modeResources": {
                                 "friendlyNames": [
                                       "@type": "text",
                                       "value": {
                                          "text": "normal",
                                          "locale": "en-US"
                                       "@type": "text",
                                       "value": {
                                          "text": "regular",
                                          "locale": "en-US"
                              "modeResources": {
                                 "friendlyNames": [
                                       "@type": "text",
                                       "value": {
                                          "locale": "en-US"
                                       "@type": "text",
                                       "value": {
                                          "locale": "en-US"
Note, I did change the "friendlyName" to "Forum Light" just to make it easier for me to differentiate this light from others.
2 comments
Problem is not with the discovery. It discovers for me. It's when I try to control the mode for that light.
When interacting with modes on a particular device, the utterance must follow one of two formats:
  • Alexa, set the "mode_name" on the "device_name" to "supported_mode_value"
  • Alexa, set the "mode_name" to "supported_mode_value"
Note, in that second interaction, Alexa may need to ask you to clarify what device you're referring to.
Using the Discover.Response JSON posted above, I received the following directives for the following utterances:
Utterance: Alexa, set the 'scene' on the 'forum light' to 'normal'
    "directive": {
        "header": {
            "namespace": "Alexa.ModeController",
            "name": "SetMode",
            "messageId": "11a44bcb-2de7-4f30-9045-c6a10c5f9fb3",
            "correlationToken": "token-redacted"
        "endpoint": {
            "scope": {
                "type": "BearerToken",
                "token": "token-redacted"
            "cookie": {}
        "payload": {
            "mode": "SceneMode.Normal"
To summarize, I don't think there was anything wrong with the device's discover response either, it just looks like the utterance that you're attempting, "Alexa, set light scene to normal" does not follow a supported utterance format. If you instead say "Alexa, set the scene on the light to normal" I suspect your back-end will receive the expected directive.
