Hi, I would like to add ffsetup into my router, and I have several question about it.
1. If I want to make my router supports ffsetup that other amazon device can be setup via my router, I should follow the step in "Frustration-Free Setup developer console", right?
2. According to the following post, I suggest that the step of integrate simple setup is
a. using simple setup SDK to integrate simple setup function into your device firmware
b. test your firmware and device
But how do I test my firmware and device?
https://developer.amazon.com/blogs/alexa/post/5d0905b9-6b95-4b94-9c82-e4ab0cc332f9/announcing-simple-setup-for-your-wi-fi-zigbee-and-bluetooth-preview-devices
3. I suggest that the device is used to identify the device by amazon device setup service. How do I add the device key in the SDK?
4. The readme in SDK is support that "Building", "Running the tests", "Building and running the demo". How do I run the ffsetup?
