newuser-f8d94517-6454-4c01-9694-4b1f5c58c38a avatar image
DispatchException: Unable to find a suitable request handler
I have this error when I run my skill:
ask_sdk_runtime.exceptions.DispatchException: Unable to find a suitable request handler.
Can anyone help me?
Here is my code:
# -*- coding: utf-8 -*-
# This sample demonstrates handling intents from an Alexa skill using the Alexa Skills Kit SDK for Python.
# Please visit https://alexa.design/cookbook for additional examples on implementing slots, dialog management,
# session persistence, api calls, and more.
# This sample is built using the handler classes approach in skill builder.
import freesound
import logging
import ask_sdk_core.utils as ask_utils
import os
from ask_sdk_s3.adapter import S3Adapter
s3_adapter = S3Adapter(bucket_name=os.environ["S3_PERSISTENCE_BUCKET"])
from ask_sdk_core.skill_builder import CustomSkillBuilder
from ask_sdk_core.dispatch_components import AbstractRequestHandler
from ask_sdk_core.dispatch_components import AbstractExceptionHandler
from ask_sdk_core.handler_input import HandlerInput
from ask_sdk_model import Response
from ask_sdk_model.interfaces.audioplayer import AudioItem, Stream, PlayDirective, PlayBehavior
import boto3
import botocore
from botocore.exceptions import NoCredentialsError
import urllib
logger = logging.getLogger(__name__)
logger.setLevel(logging.INFO)
# COSTANT
API_KEY = "X"
NUMBER_OF_RESULT = 2
S3_BUCKET_ACCESS_KEY = 'X'
S3_BUCKET_SECRET_KEY = 'X'
class LaunchRequestHandler(AbstractRequestHandler):
"""Handler for Skill Launch."""
def can_handle(self, handler_input):
# type: (HandlerInput) -> bool
return ask_utils.is_request_type("LaunchRequest")(handler_input)
def handle(self, handler_input):
# type: (HandlerInput) -> Response
speak_output = "Welcome, you can say Play or Help. Which would you like to try?"
reprompt_text = "Try to say Play snow"
return (
handler_input.response_builder
.speak(speak_output)
.ask(reprompt_text)
.response
class CaptureTitleIntentHandler(AbstractRequestHandler):
return ask_utils.is_intent_name("CaptureTitleIntent")(handler_input)
return {
'directives': [{
'type': 'AudioPlayer.Play',
'playBehavior': 'REPLACE_ALL',
'audioItem': {
'stream': {
'token': '2',
'url': 'URL',
'offsetInMilliseconds': 1
'shouldEndSession': True
class PlaybackNearlyFinishedEventHandler(AbstractRequestHandler):
return ask_utils.is_request_type("AudioPlayer.PlaybackNearlyFinished")(handler_input)
return {
'directives': [{
'playBehavior': 'ENQUEUE',
'audioItem': {
'stream': {
'token': '1',
'expectedPreviousToken': '2',
'url': 'URL',
class ReproduceIntentHandler(AbstractRequestHandler):
return ask_utils.is_intent_name("ReproduceIntent")(handler_input)
speak_output = "The download link of song is "
return (
.response
class NextSoundIntentHandler(AbstractRequestHandler):
"""Handler for Help Intent."""
return ask_utils.is_intent_name("AMAZON.NextIntent")(handler_input)
return {
'directives': [{
'type': 'AudioPlayer.Stop'
class HelpIntentHandler(AbstractRequestHandler):
return ask_utils.is_intent_name("AMAZON.HelpIntent")(handler_input)
speak_output = "You can say Play or I want hear! How can I help?"
return (
.ask(speak_output)
.response
class CancelOrStopIntentHandler(AbstractRequestHandler):
"""Single handler for Cancel and Stop Intent."""
return (ask_utils.is_intent_name("AMAZON.CancelIntent")(handler_input) or
ask_utils.is_intent_name("AMAZON.PauseIntent")(handler_input) or
ask_utils.is_intent_name("AMAZON.StopIntent")(handler_input))
return {
'directives': [{
class SessionEndedRequestHandler(AbstractRequestHandler):
"""Handler for Session End."""
return ask_utils.is_request_type("SessionEndedRequest")(handler_input)
return {
'directives': [{
#return handler_input.response_builder.response
class IntentReflectorHandler(AbstractRequestHandler):
"""The intent reflector is used for interaction model testing and debugging.
It will simply repeat the intent the user said. You can create custom handlers
for your intents by defining them above, then also adding them to the request
handler chain below.
return ask_utils.is_request_type("IntentRequest")(handler_input)
intent_name = ask_utils.get_intent_name(handler_input)
speak_output = "You just triggered " + intent_name + "."
return (
# .ask("add a reprompt if you want to keep the session open for the user to respond")
.response
class CatchAllExceptionHandler(AbstractExceptionHandler):
"""Generic error handling to capture any syntax or routing errors. If you receive an error
stating the request handler chain is not found, you have not implemented a handler for
the intent being invoked or included it in the skill builder below.
def can_handle(self, handler_input, exception):
# type: (HandlerInput, Exception) -> bool
return True
def handle(self, handler_input, exception):
# type: (HandlerInput, Exception) -> Response
logger.error(exception, exc_info=True)
speak_output = "Sorry, I had trouble doing what you asked. Please try again."
return (
.ask(speak_output)
.response
sb = CustomSkillBuilder(persistence_adapter=s3_adapter)
sb.add_request_handler(LaunchRequestHandler())
sb.add_request_handler(CaptureTitleIntentHandler())
sb.add_request_handler(ReproduceIntentHandler())
sb.add_request_handler(HelpIntentHandler())
sb.add_request_handler(NextSoundIntentHandler())
sb.add_request_handler(PlaybackNearlyFinishedEventHandler())
sb.add_request_handler(CancelOrStopIntentHandler())
sb.add_request_handler(SessionEndedRequestHandler())
sb.add_request_handler(IntentReflectorHandler())
sb.add_exception_handler(CatchAllExceptionHandler())
lambda_handler = sb.lambda_handler()
alexa skills kitalexaintentsechopython
Which intent are you trying to invoke when you are getting this error? This error indicates that there are no handlers registered for that request.
Gaetano@Amazon avatar image
Gaetano@Amazon answered
can you please confirm you have a handler registered for the IntentRequest your backend is receiving?
Please share the JSON request and the skill-ID so we can have a better look at it.
Thanks,
Gaetano
4 comments
Skill ID: amzn1.ask.skill.b90ec4f7-fe0f-4442-bd13-0d5544181e9b
Thank you very much
Gaetano@Amazon avatar image Gaetano@Amazon ♦ newuser-f8d94517-6454-4c01-9694-4b1f5c58c38a ·
can you share the JSON request as well?
thanks
I don't know where is the problem in my code. Which request should I share?
