newuser-94224243-d73d-44a4-867a-b7507db26cef avatar image
newuser-94224243-d73d-44a4-867a-b7507db26cef asked ·
An error occurs on trying to purchase an IAP item as able to purchase IAP with UK/DE accounts but unable to purchase IAP with USA account
proguard-rules.pro have following rules
-optimizations !code/allocation/variable
-optimizationpasses 1
-dontwarn com.amazon.**
 -keep class com.amazon.** {*;}
 -keepattributes *Annotation*
 -keep public class * extends com.amazon.device.messaging.ADMMessageReceiver
 -keep public class * extends com.amazon.device.messaging.ADMMessageHandlerBase
 -keepclassmembers public class * extends com.amazon.device.messaging.ADMMessageReceiver { *; }
 -keepclassmembers public class * extends com.amazon.device.messaging.ADMMessageHandlerBase { *; }
build.gradle have following lines
maven { url "http://storage.googleapis.com/r8-releases/raw" }
classpath 'com.android.tools:r8:1.6.42'  // Must be before the Gradle Plugin for Android.
release {
            debuggable false
            minifyEnabled true
            shrinkResources true
            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
/*            buildConfigField "boolean", "IS_DEBUG_ABLE", 'false'*/
            signingConfig signingConfigs.release    // Add this line
Application failed the Test Result
An error occurs on trying to purchase an IAP item"" error message
Expected Result: IAP items should get purchased without any error message. NOTE:able to purchase IAP with UK/DE accounts but unable to purchase IAP with USA account
iapamazon appstore
Have you found a solution? Our app suddenly started to have this problem. R8 is disabled for the app:
android.enableR8=false
Everything works fine on our testing devices for both the debug version and the release version. The report says the error occurs for Fire TV devices. The message is generated by Amazon. I suspect the purchase is successful and response.getRequestStatus() returns SUCCESSFUL.
