newuser-faf7a9b1-07ab-4521-96c1-d10291e8d5f5 avatar image
Update Slot Values Dynamically during dialog
Hi everyone,
my skill is using dynamic slot values a lot. However, they are all loaded at launch request (.addDirective with Dialog.UpdateDynamicEntities). I did not have too much luck trying to update them during a dialog to be able to listen for different options based on what the user said in an earlier stage of the dialog.
To me, it looks like I can only update the dynamic Slot Values at the very end of an intent.
Is there any way of doing this after each question in a dialog?
alexa skills kitslotsdialog modeldialog directivedynamic entities
Marlon avatar image
Marlon answered
Same problem here, can anyone help?
Phil McGee avatar image
Phil McGee answered
While we're at it, how about adding DynamicEntities in a RequestInterceptor so they are available *before* the intent is processed?
3 comments
Am I correct in assuming that this will do the same as it already does by loading all of the dynamic entities in the launch request?
dynamic entities can be sent as a result of an Intent response, hence, LaunchRequest is supported. Please check this reference:
https://developer.amazon.com/en-US/docs/alexa/custom-skills/use-dynamic-entities-for-customized-interactions.html#use-of-dynamic-entities-in-an-intent-response
Regards,
Gaetano
Yeah it will be cool if we can have dynamic entities before. It will solve the problem of opening a skill with "open ... and ..." that as for now can't use dynamic entities
