newuser-a7b0db83-bc36-4706-bd00-659df955612b avatar image
Alexa's voice response to Smart Home Skill
I followed the example in the documentation and implemented the Power Control API with a node.js Lambda function. The Smart Home skill I created for turning device on and off is working fine with my smart light switch. However, it seems odd that:
1. Alexa does NOT respond with "OK". It only responded with a two tone sound. Is this normal?
2. I read from another thread saying that the "Output Speech" cannot be customized with Smart Home Skill. Is that still true?
3. When I test it in the Alexa Developer Console, the "Skill I/O" section doesn't show the JSON request/response at all. On top, I only see it displaying "<Audio only response>". Is this normal?
Thanks in advance,
Joseph
responsesmart homepowercontroller
KirkC@Amazon avatar image
KirkC@Amazon answered
This is the result of a user customization setting in the Alexa app called "Brief Mode." This is found under Settings > Voice Responses. If you enable this option then yes, it's expected that your device will respond with a two-tone sound.
Yes, this is still correct. Smart Home skills do not allow developers to customize Alexa's verbal responses.
3. When I test it in the Alexa Developer Console, the "Skill I/O" section doesn't show the JSON request/response at all. On top, I only see it displaying "Audio only response". Is this normal?
It's normal that the "Skill I/O" section is blank for a smart home skill. However, if in the left-hand side the only response you're getting is "audio only response" then it can mean a few things.
It could be that the request didn't resolve the the skill in question (the "Test" tab's responses are not limited to the one skill you're attempting to test). It could be a browser issue, like an add-on interfering with the console or having multiple tabs open on the "Test" page has also been known to cause trouble. It could also be because local software is interfering with the simulator, for example an anti-virus.
https://forums.developer.amazon.com/questions/153911/issue-when-running-test-of-skill-in-new-alexa-cons.html
newuser-a7b0db83-bc36-4706-bd00-659df955612b answered
Turning off Brief Mode indeed fixes both #1 and #3. Thanks.
