newuser-2eef1a59-d220-426b-a16b-5337be0a1d2f avatar image
Skill won't close the session after fulfilling a request?
Here is my index.js
// This sample demonstrates handling intents from an Alexa skill using the Alexa Skills Kit SDK (v2).
// Please visit https://alexa.design/cookbook for additional examples on implementing slots, dialog management,
// session persistence, api calls, and more.
const Alexa = require('ask-sdk-core');
const LaunchRequestHandler = {
canHandle(handlerInput) {
return Alexa.getRequestType(handlerInput.requestEnvelope) === 'LaunchRequest';
handle(handlerInput) {
const speakOutput = 'Welcome, this is an interactive Alan Turing skill. You can start a conversation or ask for help.';
return handlerInput.responseBuilder
.speak(speakOutput)
.reprompt(speakOutput)
.getResponse();
const theimitationgameIntentHandler = {
return Alexa.getRequestType(handlerInput.requestEnvelope) === 'IntentRequest'
&& Alexa.getIntentName(handlerInput.requestEnvelope) === 'theimitationgameIntent';
const speakOutput = 'Would you like to ask another question?';
.speak(speakOutput)
//.reprompt('add a reprompt if you want to keep the session open for the user to respond')
.getResponse();
const HelpIntentHandler = {
&& Alexa.getIntentName(handlerInput.requestEnvelope) === 'AMAZON.HelpIntent';
const speakOutput = 'To start a conversation, you can ask questions like can machines think, what is your legacy, or what is the imitation game?';
.speak(speakOutput)
.getResponse();
const CancelAndStopIntentHandler = {
&& (Alexa.getIntentName(handlerInput.requestEnvelope) === 'AMAZON.CancelIntent'
|| Alexa.getIntentName(handlerInput.requestEnvelope) === 'AMAZON.StopIntent');
const speakOutput = 'Goodbye, thank you for playing The Imitation Game!';
.speak(speakOutput)
.getResponse();
const SessionEndedRequestHandler = {
return Alexa.getRequestType(handlerInput.requestEnvelope) === 'SessionEndedRequest';
// Any cleanup logic goes here.
return handlerInput.responseBuilder.getResponse();
// The intent reflector is used for interaction model testing and debugging.
// It will simply repeat the intent the user said. You can create custom handlers
// for your intents by defining them above, then also adding them to the request
// handler chain below.
const IntentReflectorHandler = {
return Alexa.getRequestType(handlerInput.requestEnvelope) === 'IntentRequest';
const intentName = Alexa.getIntentName(handlerInput.requestEnvelope);
const speakOutput = `You just triggered ${intentName}`;
.speak(speakOutput)
.getResponse();
// Generic error handling to capture any syntax or routing errors. If you receive an error
// stating the request handler chain is not found, you have not implemented a handler for
// the intent being invoked or included it in the skill builder below.
const ErrorHandler = {
canHandle() {
return true;
handle(handlerInput, error) {
console.log(`~~~~ Error handled: ${error.stack}`);
const speakOutput = `Sorry, I had trouble doing what you asked. Please try again.`;
.speak(speakOutput)
.getResponse();
// The SkillBuilder acts as the entry point for your skill, routing all request and response
// payloads to the handlers above. Make sure any new handlers or interceptors you've
// defined are included below. The order matters - they're processed top to bottom.
exports.handler = Alexa.SkillBuilders.custom()
.addRequestHandlers(
LaunchRequestHandler,
theimitationgameIntentHandler,
HelpIntentHandler,
CancelAndStopIntentHandler,
SessionEndedRequestHandler,
IntentReflectorHandler, // make sure IntentReflectorHandler is last so it doesn't override your custom intent handlers
.addErrorHandlers(
ErrorHandler,
.lambda();
Here is my package.json
"name": "the-imitation-game",
"version": "1.1.0",
"description": "alexa utility for quickly building skills",
"main": "index.js",
"scripts": {
"test": "echo \"Error: no test specified\" && exit 1"
"author": "Amazon Alexa",
"license": "ISC",
"dependencies": {
"ask-sdk-core": "^2.6.0",
"ask-sdk-model": "^1.18.0",
"aws-sdk": "^2.326.0"
skillcertificationdeveloper account
