I have built a flutter application in which the user can create a form and select fields. Now I want to give flexibility to the user to add data to fields(chosen) using Alexa.
Assume that user has selected these fields using my flutter application and I have saved it in firebase(or on any NoSQL database) -
Shop Name
Address
Establishment Year
Now the user invoke my alexa skill.
After greeting I will ask the user "Please answer the following -".
Now I want to ask the user "Shop Name".
I expect user to enter shop name. Say "Parle".
Then I will send "Entered value is Parle. Is it correct?".
If the user says yes then I move on to the next question "Email".
I expect user to enter shop's email. Say "abc@xyz.com".
Then I will send "Entered value is abc@xyz.com . Is it correct?".
Similarly I will ask the user all the questions and then get the result and save it in the database.
Now the problem since I don't have a well defined schema. Since the user may have selected -
Shop Name
Country
Phone
Items Available
Thus I am not able to make a slot for an intent since the fields are variable. Please help me how I can achieve this functionality.
