newuser-50f645bb-c539-4cff-8635-2e212915d484 avatar image
newuser-50f645bb-c539-4cff-8635-2e212915d484 asked ·
How do I get dialogs working?
I have the following intent:
"intents": [
"name": "setLocationIntent",
"slots": [
"name": "deviceLocation",
"type": "AMAZON.SearchQuery",
"samples": [
"Location is {deviceLocation}",
"{deviceLocation}",
"set location to {deviceLocation}"
"samples": [
The intent is chained to when a user initiates a launch request but the device is not in a dynamo db I have set up. The chaining to 'setLocationIntent' works but then when try to respond to the prompt with the slot value it will only accept the one utterance "set location to {deviceLocation}" that was set up with the intent instead of the utterances set up with the slot in 'dialogs'.
I have tried this with both 'ElicitSlotDirective' and 'DelegateDirective' in the relevant lambda function but neither appear to be working. Lambda section included below.
speech = ("Location of Alexa device has not been set.")
location_directive = ElicitSlotDirective(
slot_to_elicit = "deviceLocation",
updated_intent = Intent(
name = "setLocationIntent",
confirmation_status = IntentConfirmationStatus.NONE,
slots = {
"deviceLocation": Slot(
name= "deviceLocation",
confirmation_status = SlotConfirmationStatus.NONE
location_directive = DelegateDirective(updated_intent = "setLocationIntent")
(handler_input.response_builder
.speak(speech)
.add_directive(location_directive))
return handler_input.response_builder.response
interaction modeldialog modelutterancesdialog directive
newuser-50f645bb-c539-4cff-8635-2e212915d484 answered ·
Here's the code in a more readable format.
Just to re-iterate. Alexa won't accept the first list of "samples" within "slots". It only accepts the single sample "set location to {deviceLocation}".
The 3 samples were created in the 'User utterances' section of the slots dialog page in the dev console.
            "intents": [
                    "slots": [
                            "samples": [
                                "{deviceLocation}",
                    "samples": [
                    slots = {
                .speak(speech)
Anand@Amazon avatar image
Anand@Amazon answered ·
Hi there,
Can you also share skill ID for further debugging?
