newuser-ad5ec666-9876-4c50-8362-e4bf3af89e1f avatar image
Failed to save skill information
Trying to save a smart home skill, per the tutorial, and I'm getting the following error (SMART HOME tab), when saving the ARN for the lambda function:
  • The requested content has an invalid property 'skillmanifest'.
Any ideas? Thanks in advance!
skilllambdasmart home
newuser-96ee2de4-152d-4dfc-9ccb-a1e6967369c1 avatar image
newuser-96ee2de4-152d-4dfc-9ccb-a1e6967369c1 answered
I have the same problem when i try to create a new Flash Briefing skill. I receive this message even if i compile only field: " Custom Error Message "
apeksha avatar image
apeksha answered
Hello there,
I have escalated your issue to the internal team for further investigation. I will get back when i have more information on this issue. We appreciate your patience while we work on this issue.
Thanks! Seems to be working now.
I had to delete the trigger and re-add it as it was disabled and I could not get it to enable (enable->save and it was back to disabled).
Now it's working.
webtop avatar image
webtop answered
Same here, creating a skill via this tutorial: https://developer.amazon.com/docs/smarthome/steps-to-build-a-smart-home-skill.html
Same error message, same place: saving the ARN
Thanks for the help
NewNewUser-7dc88708-710f-4287-8b03-f86260a7bfbf avatar image
NewNewUser-7dc88708-710f-4287-8b03-f86260a7bfbf answered
Ditto here. Clicking the "Save" button on a simple Flash Briefing skill also results in the "skillmanifest" error message. Skill creation/saving appears to be broken across the board.
On the plus side, reviewers of Amazon skills who are processing the review queue today have fewer skills to process. If users can't create them, then they can't publish them and therefore the reviewers can't review them. Maybe they'll even get the entire queue cleared out and go home early!
Okay. It looks to be fixed now for me. I was able to click the Save button without the error appearing.
webtop avatar image
webtop answered
Looks to be solved now :) I just clicked save and moved right on along.
Thank you Apeksha@amazon
apeksha answered
Hello Developers,
The issue is resolved now. Please check form your end and confirm if it still occurs.
