Kmart avatar image
Kmart asked
Alexa send three request to Lambda but not play the camera on Echo
I build a Smart Home Camera Skill, When tap the Camera button on Echo Show, Alexa send request to AWS Lambda while saying "em the camera is responding" but played faild at the end.
And there were three times requests at the Lambda Logs.
below is the response of Sever
RTSP Server Fiddler Log.pngresponse.json.txt
smart homecamera
Hello @Kmart and thanks for your message.
As mentioned in another thread you posted, the URL is not reachable via internet. VLC is throwing the following error:
Connection failed
VLC could not connect to 'rtsp://1.rtsp.dvr163.com:443/live?
Please make sure that it is possible to open the stream via VLC and that it also fulfil the requirements listed in the documentation.
Regards,
Barry
2 comments
Kmart avatar image Kmart commented ·
Hi Barry, Thank you for your response.
Is is right that if the RTSP is correct it must can be played on VLC ?
Amazon_Bernardo Bezerra avatar image Amazon_Bernardo Bezerra ♦♦ Kmart commented ·
Hi @Kmart,
Yes, that is correct. For Alexa to be able to stream the RTSP, VLC must be able to stream it as well.
Regards,
Barry
