DaleMurray avatar image
DaleMurray asked
Amazon music HD stream directly to endpoint
Not sure if this is the correct place for this, but here goes.
My pet peeve with Amazon HD, Tidal, Deezer, Qobuz is the inability to stream directly to an endpoint. With Spotify I registered my NAD 658 DAC as an endpoint then using any spotify interface (phone, web, laptop, etc) I could select my DAC as the output source. Did not require Airplay or Bluetooth.
I could even shutdown the device that started playing the stream and the music continues. I could open spotify on a different device and continue managing the already running stream.
It seems archaic to use phone or laptop as an intermediary between the web and endpoint.
Spotify figured this out, why can't others get on the bandwagon.
I currently use Tidal ($20 a month) and Roon ($120 a year) so I can have the same convenience as Spotify but with high fidelity sound.
While Amazon is significantly less money the lack of convenience means I will likely terminate my trial regardless of savings.
If nothing else Amazon should look into partnering with Roon.
apifeature requestappmusic
Levon@Amazon avatar image
Levon@Amazon answered
Hi DaleMurray,
Thanks for posting. Please note that this is a forum for Amazon Appstore developers. For assistance with the Amazon services as an end user, please either:
- post in Amazon Digital and Device Forum: https://www.amazonforum.com/
- contact Amazon Customer Service for support: http://www.amazon.com/customerservice
Thanks!
