newuser-774a13d7-010a-44f7-a720-1beb4838744c avatar image
Questions about your FSS documents
I would like to know about FSS.
A. Manufacturing
https://developer.amazon.com/ja/docs/frustration-free-setup/provisionee-manufacturing.html
In above document "DHA Process"
DHA Process
2.The X.509 client includes the public key in a Certificate Signing Request (CSR) and sends this CSR to Amazon.
In this explanation, we need to send CSR to Amazon.
I can't understand what is required. Is it necessary to send the CSR for every machine on production.
B. Certification
https://developer.amazon.com/ja/docs/frustration-free-setup/wi-fi-provisionee-certification.html
Provisionee Test Cases 3P2-BC-01
Please explain, what is FC compatible equipment.
about your fss document
raycuraso avatar image
raycuraso answered
Thank you for reaching out.
1) The manufacturing documentation is miss-leading in this case. FOr Manufacturing keys, Amazon will send your a Yubi Key that will be your CA. FOr each device you manufacture, you will sign a certificate using the Yubi Key.
2) "FC" stands for fullfillment center. In the certification process "It must be scannable by FC compatible equipment." means equipments that is compatible operationaly with the equipment used in AMazon fullfillment centers. If you following the barcode specification in https://developer.amazon.com/ja/docs/frustration-free-setup/provisionee-manufacturing-barcode-specification.html your barcode will be compatible.
