I can't figure out what I'm doing wrong in my skill. Highlight mode is not working and the content doesn't stay in view even though speakItem claim to do it automatically ...
I have the same problem in another way more complicated APL document where the ID is dynamic. Can someone explain me what I'm doing wrong?
EDIT 30/09/2019 (Morning): I managed to get the automated scrolling working but the highlightMode is still not working ... Code updated.
EDIT 30/09/2019 (Afternoon): Got it to work. I tried to change the highlighting color and now it does everything it should. The code is updated and working ...
{ "type": "APL", "version": "1.1", "theme": "dark", "import": [], "settings": {}, "resources": [], "styles": { "karaokeText": { "values": [ { "color": "colorAfterHighlighting", "textAlign": "center", "textAlignVertical": "center", "fontFamily": "Amazon Ember Display", "fontSize": "26" }, { "when": "${state.karaoke}", "color": "colorBeforeHighlighting" }, { "when": "${state.karaokeTarget}", "color": "HighlightedLineColor" } ] } }, "onMount": [], "graphics": {}, "commands": {}, "layouts": {}, "mainTemplate": { "parameters": [ "payload" ], "items": [ { "description": "Contenitore principale", "type": "Container", "width": "100%", "height": "100%", "numbered": false, "alignItems": "center", "direction": "column", "justifyContent": "center", "items": [ { "type": "Frame", "width": "99%", "height": "99%", "backgroundColor": "white", "borderColor": "#0075AA", "borderRadius": "1000", "borderWidth": "7", "alignSelf": "center", "position": "absolute" }, { "type": "Image", "width": "45%", "source": "...", "align": "center", "alignSelf": "center", "position": "absolute", "bottom": "330" }, { "type": "ScrollView", "width": "90%", "height": "100%", "alignSelf": "center", "top": "150", "item": [ { "type": "Container", "item": [ { "type": "Text", "id": "articleInfo", "text": "${PathToText}", "speech": "${PathToSpeech}", "style": "karaokeText" }, { "type": "Text", "id": "articleContent", "text": "${PathToText}", "speech": "${PathToSpeech}", "style": "karaokeText" } ] } ] } ] } ] } }
commands.json
[ { "type": "SpeakItem", "componentId": "articleInfo", "highlightMode": "line", "align": "first" }, { "type": "Idle", "delay": 400 }, { "type": "SpeakItem", "componentId": "articleContent", "highlightMode": "line", "align": "first" } ]
APL render function
if (supportsAPL(handlerInput)) { return handlerInput.responseBuilder .addDirective({ type: 'Alexa.Presentation.APL.RenderDocument', token: 'articleToken', document: require('./article_presentation/layout.json'), datasources: { resources: { type: 'object', properties: { ssmlText: `<speak>${articleText}</speak>`, ssmlDate: `<speak>${articleDate}</speak>` }, transformers: [ { inputPath: 'ssmlText', outputName: 'articleSpeech', transformer: 'ssmlToSpeech' }, { inputPath: 'ssmlText', outputName: 'articleText', transformer: 'ssmlToText' }, { inputPath: 'ssmlDate', outputName: 'dateSpeech', transformer: 'ssmlToSpeech' }, { inputPath: 'ssmlDate', outputName: 'dateText', transformer: 'ssmlToText' } ] } } }) .addDirective({ type: 'Alexa.Presentation.APL.ExecuteCommands', token: 'articleToken', commands: require('./article_presentation/commands.json') }) .reprompt(repromptSpeech) .getResponse(); }
I also have another question, a bit off-topic ...
Is there a way I can isolate the datasource like I did with commands and layout when I need to use a value that I can get only in the index.js file?
