MoonDekade avatar image
MoonDekade asked
Proactive Event - Status 202 but no notification
skill id: amzn1.ask.skill.3d3e4626-a36a-41dd-ad01-817a045a5d23
My event calls seem to be successful (status code 202) but no notifications are received. My endpoint is not called. My endpoint works and is called successfully for my other Intents.
I am not using a Lambda endpoint.
Since the MediaContent.Available event uses a predefined response, I don't understand the need for an endpoint anyway.
    "manifest": {
        "apis": {
            "custom": {
                "endpoint": {
                    "uri": "https://xyz.ngrok.io",
                    "sslCertificateType": "Wildcard"
                "interfaces": []
        "manifestVersion": "1.0",
        "permissions": [
                "name": "alexa::alerts:reminders:skill:readwrite"
                "name": "alexa::devices:all:notifications:write"
        "events": {
            "publications": [
                    "eventName": "AMAZON.MessageAlert.Activated"
                    "eventName": "AMAZON.MediaContent.Available"
            "endpoint": {
            "regions": {
                "NA": {
                    "endpoint": {
        "publishingInformation": {
            "locales": {
                "en-US": {
                    "name": "askcli-test1",
                    "summary": "Sample Short Description",
                    "description": "Sample Full Description",
                    "examplePhrases": [
                        "Alexa open squid test one"
            "isAvailableWorldwide": true,
            "testingInstructions": "Sample Testing Instructions.",
            "category": "KNOWLEDGE_AND_TRIVIA",
            "distributionCountries": []
Example POST
    "hostname": "api.amazonalexa.com",
    "port": 443,
    "path": "/v1/proactiveEvents/stages/development",
    "method": "POST",
    "headers": {
        "Content-Type": "application/json",
        "Content-Length": 544,
        "Authorization": "Bearer ..."
    "timestamp": "2019-09-17T22:03:21.379Z",
    "referenceId": "SampleReferenceId1568757801382x",
    "expiryTime": "2019-09-18T08:03:21.379Z",
    "event": {
        "name": "AMAZON.MediaContent.Available",
        "payload": {
            "availability": {
                "startTime": "2019-10-01T20:00:00Z",
            "provider": {
                "name": "localizedattribute:providerName"
            "method": "AIR"
        "content": {
            "name": "localizedattribute:contentName",
            "contentType": "EPISODE"
"localizedAttributes": [
        "locale": "en-US",
        "providerName": "Squid Video",
        "contentName": "History of Squids"
"relevantAudience": {
    "type": "Multicast",
    "payload": {}
POST RESPONSE
202 Accepted
Content-Length: 0
Connection: keep-alive
Server: Server
Date: Tue, 17 Sep 2019 22:58:57 GMT
X-Amzn-RequestId: 26b6a0b9-a419-c4a7-6d36-8b9df9350a53
x-amz-rid: FGD9QDVDSRVCC19RW0Y1
Vary: Accept-Encoding,X-Amzn-CDN-Cache,X-Amzn-AX-Treatment,User-Agent
X-Cache: Miss from cloudfront
Via: 1.1 bedc7f726c5c61bbe5343fc78dc92c32.cloudfront.net (CloudFront)
X-Amz-Cf-Pop: MIA3-C3
X-Amz-Cf-Id: j0qHP4UqHRCS92aZ27ObS3SYEJzds5ngvcp4s9aAKq5_KR6P0Wg_cA==
proactive events
Hello @MoonDekade and thanks for your message.
The 202 HTTP response means that the payload was received and is not malformed, but does not necessarily means that it has been correctly processed by the service.
Taking a look at the documentation and comparing with your example POST, I noticed that you have a "relevantAudience" key, which does not appear in the one shown in the documentation. Have you tried without it?
If this does not solve your issue, please share the activity ID of the utterance that you are using to trigger the notification. This page explains how to retrieve those.
Regards,
Barry
