John Gaby avatar image
John Gaby asked ·
getProductData fails when connecting to Amazon store
I am trying to implement in-app purchasing. My app is xamarin based and I am using Amazon's iap plugin. If I test it using Amazon's App Tester Plugin, everything works find. However when I publish my app using Amazon's Live App Testing service, I cannot retrive the product list using the getProductData function. It is either returning failed or an empty list. The logcat that is generated when I make the call is shown below.
Can anyone tell me what might be going wrong?
--------- beginning of main
08-14 16:41:51.792 31322-31322/? D/AmazonIapV2 Bridge: Executing native GetProductData
08-14 16:41:51.792 31322-31322/? I/AmazonIapV2: getProductData called
08-14 16:41:51.792 31322-31322/? I/AmazonIapV2: getProductData for skus:flippixdollhouse,flippixbridges,flippixtime,flippixprofessions,flippixgreece,flippixschool,flippixfair,
08-14 16:41:51.793 31322-31322/? D/AmazonIapV2 Bridge: java method called
08-14 16:41:51.794 31322-31322/? D/AmazonIapV2Android: Successfully called native code in 1 ms
08-14 16:41:51.881 4428-9155/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared(null) - using H:072d20a11701ea8841cdb762fde27114
08-14 16:41:51.881 4428-9155/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared() - using H:072d20a11701ea8841cdb762fde27114, returning true
08-14 16:41:51.881 4428-7830/? I/AmazonAppstore.IAP/IapAD3LoggingDelegate: IAP event: 0ca0a081-15b0-471a-85f2-2ac6fac0a9be IapGetItemCommandInitiated
08-14 16:41:51.882 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: getDeviceType() called, isChildDeviceTypeUsed = false
08-14 16:41:51.882 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: child device type special cases did not apply
08-14 16:41:51.883 4428-7830/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared(null) - using H:072d20a11701ea8841cdb762fde27114
08-14 16:41:51.883 4428-7830/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared() - using H:072d20a11701ea8841cdb762fde27114, returning true
08-14 16:41:51.884 521-1386/? W/PackageManager: com.amazon.canary is not installed for user 0
08-14 16:41:51.884 521-939/? W/PackageManager: com.amazon.fv is not installed for user 0
08-14 16:41:51.884 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: getDeviceType() called, isChildDeviceTypeUsed = false
08-14 16:41:51.884 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: child device type special cases did not apply
08-14 16:41:51.893 4428-7830/? I/AmazonAppstore.AvailabilityService: putMeasurement - venezia-metrics
08-14 16:41:51.894 4428-7830/? I/AmazonAppstore.IAP/IapAD3LoggingDelegate: IAP event: 0ca0a081-15b0-471a-85f2-2ac6fac0a9be IapGetItemCommandDiscoveryRequestInitiated
08-14 16:41:51.897 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: getDeviceType() called, isChildDeviceTypeUsed = false
08-14 16:41:51.897 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: child device type special cases did not apply
08-14 16:41:51.898 4428-7830/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared(null) - using H:072d20a11701ea8841cdb762fde27114
08-14 16:41:51.898 4428-7830/? I/AmazonAppstore.AccountSummaryProviderImpl: isAccountPrepared() - using H:072d20a11701ea8841cdb762fde27114, returning true
08-14 16:41:51.898 521-2197/? W/PackageManager: com.amazon.canary is not installed for user 0
08-14 16:41:51.898 521-6592/? W/PackageManager: com.amazon.fv is not installed for user 0
08-14 16:41:51.899 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: getDeviceType() called, isChildDeviceTypeUsed = false
08-14 16:41:51.899 4428-7830/? I/AmazonAppstore.BasicDeviceInspector: child device type special cases did not apply
iappurchasing
Any chance getting this post approved any time soon? It has been 2 days now.
Levon@Amazon avatar image
Levon@Amazon answered ·
Hi John,
Thanks for posting! We have identified and already fixed an issue related to IAP within Live App Testing environment. The issue does not affect public live releases, so if you release your app publicly, IAP will work as intended. The issue in LAT has been fixed, so if you submit a new test in LAT, your IAP functionality should work correctly now. If you take no action, we will republish your test app in LAT within a few days and IAP should start working from that point. Thanks!
2 comments
It seems to be working now, thanks.
Thank you for the update John! We are glad it's working now, and apologise for any inconvenience that might have caused you. Thanks!
