Manuel Vianello avatar image
Manuel Vianello asked
Alexa.ThermostatController - Cumulative turn on/off Thermostats command
Dear all
I'm trying to implementing the cumulative turn on/off thermostats command but, when I try to use the cumulative thermostats on/off buttons on the Alexa app, nothing happens.
I'm also logging all the Alexa requests on my Lambda function AlexaHandler but, with the thermostats cumulative on/off buttons, no request arrives.
With another device type (such as Switch) these buttons work correctly.
Could you please provide me a solution for this problem?
Thank you in advance!
alexaalexa smart homesmart homethermostat
Gaetano@Amazon avatar image
Gaetano@Amazon answered
thanks for your post.
Can you please share your skill-ID and the full discovery response of the Thermostat and the Switch?
Kind regards,
Gaetano
4 comments
Manuel Vianello avatar image Manuel Vianello commented ·
Hi Gateano,
The skill-ID is: amzn1.ask.skill.fe73f9fe-c8f8-45f9-8874-dac250db25c0
The full discovery response is:
discovery.txt
Manuel
discovery.txt (7.8 KiB)
Gaetano@Amazon avatar image Gaetano@Amazon ♦ Manuel Vianello commented ·
Thanks for the information provided.
I wasn't able to perform the account linking process with the test account, can you please look into it?
Also, does the same interaction work with voice?
Kind regards,
Gaetano
Manuel Vianello avatar image Manuel Vianello Gaetano@Amazon ♦ commented ·
Hi Gateano,
The skill authentication instructions specyfied inside the Testing instructions should work now.
I tried to perform the interaction with voice but it still doesn't works.
Manuel Vianello
