Smeech avatar image
Smeech asked
Run ask commands as npm script
This is more like a bug report since there is no issue board for ask cli :(
Since my upgrade of ask-cli from 1.6.x to 1.7.x when running npm scripts containing ask commands an error is returned:
Ask-cli version: 1.7.10
Ask version: 2.7.0
Node version: 11.6.0
Script in package.json:
"deploy": "ask validate -l en-US"
Error:
> my-skill@1.0.0 bla /Users/xxxxx/Projekte/alexa-skills/my-skill
internal/modules/cjs/loader.js:605
throw err;
Error: Cannot find module '@src/utils/constants'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:603:15)
at Function.Module._resolveFilename (/Users/xxxxx/Projekte/alexa-skills/my-skill/node_modules/module-alias/index.js:49:29)
at Function.Module._load (internal/modules/cjs/loader.js:529:25)
at Module.require (internal/modules/cjs/loader.js:657:17)
at require (internal/modules/cjs/helpers.js:22:18)
at Object.<anonymous> (/Users/xxxxx/Projekte/alexa-skills/my-skill/node_modules/ask-cli/lib/commands/init/index.js:1:81)
at Module._compile (internal/modules/cjs/loader.js:721:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:732:10)
at Module.load (internal/modules/cjs/loader.js:620:32)
at tryModuleLoad (internal/modules/cjs/loader.js:560:12)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! my-skill@1.0.0 bla: `ask validate -l en-US`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the my-skill@1.0.0 bla script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /Users/xxxxx/.npm/_logs/2019-08-02T19_03_27_519Z-debug.log
ask cli
Anand@Amazon avatar image
Anand@Amazon answered
Hi there,
Thanks for reaching out to us.
I have raised your issue with our internal team and they are looking into your issue.
I will update you once I will have information to share.
newuser-e07d36b7-2fb7-4161-9417-e1cdbb084d8d avatar image
newuser-e07d36b7-2fb7-4161-9417-e1cdbb084d8d answered
Hi @Smeech,
I was unable to reproduce the issue at my end.
Repro steps:
-> Installed cli version 1.7.10 (https://www.npmjs.com/package/ask-cli) -> I have an existing skill linked to my account. Ran the following command *ask validate -s <skill-id> -l en-US -p <profile>*
Could you kindly share the details (repro steps) that you followed ?
Hello @Smeech
We are unable to repro this issue on our end.
Can you check after uninstall and re-install again?
6 comments
reinstallation didnt fix it. You can download my repository and follow these step to reproduce:
clone: https://github.com/sem4phor/alexa-boilerplate
npm run validate
This executes the command ask validate -l en-US as seen in package.json.
But it fails. Can you confirm it?
Same goes for deploy command
Hey @Smeech
Thanks for providing github link.
I cloned your project and after few changes I was able to deploy and successfully ran validate command without any issue.
Check here : https://github.com/cooldevil007/CLIValidate-Issues
I have also removed "pre-commits" and "pre-push" hooks because I was getting error while uploading to github but you can run "validate" commands with these hooks without any problem.
Check below link for screenshot details:
https://skill-screenshot.s3.amazonaws.com/Screen+Shot+2019-08-12+at+1.02.23+PM.png
I replied in a github issue in your repo :)
newuser-def5fc75-e567-482b-9c97-e9622d354a29 avatar image
newuser-def5fc75-e567-482b-9c97-e9622d354a29 answered
I fixed this issue by making sure the ask-cli was installed locally in project root and not just globally as npm module.
