Jean Vence avatar image
Jean Vence asked
Applying transformers to lists
I'm trying to use the SpeakList command and was wondering how to apply transformers to a list.
Here's my list:
    "listTemplate2Metadata": {
        "type": "object",
        "objectId": "lt1Metadata",
        "backgroundImage": {
            "contentDescription": null,
            "smallSourceUrl": null,
            "largeSourceUrl": null,
            "sources": [
                    "url": "https://d2o906d8ln7ui1.cloudfront.net/images/LT2_Background.png",
                    "size": "small",
                    "widthPixels": 0,
                    "heightPixels": 0
                    "size": "large",
                    "widthPixels": 0,
                    "heightPixels": 0
        "title": "Results for \"Cow's Milk Cheese\"",
        "logoUrl": "https://d2o906d8ln7ui1.cloudfront.net/images/cheeseskillicon.png"
    "listTemplate2ListData": {
        "type": "list",
        "listId": "lt2Sample",
        "totalNumberOfItems": 10,
        "hintText": "Try, \"Alexa, select number 1\"",
        "listPage": {
            "listItems": [
                    "listItemIdentifier": "brie",
                    "speech": "my first",
                    "ordinalNumber": 1,
                    "textContent": {
                        "primaryText": {
                            "type": "PlainText",
                            "text": "Title"
                        "secondaryText": {
                            "text": "Description"
                    "image": {
                        "sources": [
                                "url": "https://d2o906d8ln7ui1.cloudfront.net/images/md_brie.png",
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "brie"
                    "speech": "my second",
                    "ordinalNumber": 2,
                    "textContent": {
                        "primaryText": {
                            "text": "Title"
                        "secondaryText": {
                    "image": {
                        "sources": [
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "brie"
                    "speech": "my third",
                    "ordinalNumber": 3,
                    "textContent": {
                        "primaryText": {
                            "text": "Title"
                        "secondaryText": {
                    "image": {
                        "sources": [
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "brie"
Tried adding the following to a list item with no success:
            "mySpeechData": {
              "type": "object",
              "properties": {
                "title": "Sam Lee"
              "transformers": [
                  "inputPath": "title",
                  "outputName": "outputTitle",
                  "transformer": "textToSpeech"
Is it even possible to apply transformers to a list object?
Thank you for your assistance in this matter.
apllist api
Gaetano@Amazon avatar image
Gaetano@Amazon answered
Hi all,
back to the original question, I have created a layout with just one transformer, that is accepting dynamic data input:
"datasources": {
        "data": {
            "properties": {
                "values": [
                        "text": "This is the text one"
                        "text": "This is the text two"
                        "text": "This is the text three"
            "transformers": [
                    "inputPath": "values[*].text",
                    "outputName": "speech",
You can find the full layout here, it is importable into the Authoring tool by selecting the "Upload Code" button.
Kind regards,
Gaetano
thanks for your post.
The SpeakList command lets you read out loud the content of range of items inside Container or a Sequence.
However, each item should have his own "Speech" property filled, it means that there must be a textToSpeech transformer for every element.
Kind regards,
Gaetano
12 comments
How would you add a transformer to each item in the listTemplate2ListData list above? Tried adding the following to each item in the list:
  1. "mySpeechData": {
  2. "type": "object",
  3. "properties": {
  4. "title": "Sam Lee"
  5. },
  6. "transformers": [
  7. {
  8. "inputPath": "title",
  9. "outputName": "outputTitle",
  10. "transformer": "textToSpeech"
  11. }
  12. ]
  13. }
But could not get it to work. Also added:
"speech":"${data.mySpeechData.outputTitle}" in the text field of my HorizontalListItem definition. Any ideas?
please share the full APL document and datasources so we can provide you the best solution.
Thanks.
There's a limit on the forums so I created gists:
https://gist.github.com/jvence/0116a6287aa8d5f35ce87ecf6ef84e27
https://gist.github.com/jvence/64689576f5b31a83ab09ff78a7281a2a
When a SpeakList command is issued, scrolling works fine but nothing is spoken.
Jean Vence answered
Thanks but how would it look in the 'listTemplate2ListData' list above?
As you can see I tried to add the following to each element:
 "mySpeechData": {
              "type": "object",
              "properties": {
                "title": "Sam Lee"
              "transformers": [
Jean Vence answered
    "type": "APL",
    "version": "1.1",
    "settings": {},
    "theme": "dark",
    "import": [
            "name": "alexa-layouts",
            "version": "1.0.0"
    "resources": [
            "description": "Stock color for the light theme",
            "colors": {
                "colorTextPrimary": "#151920"
            "description": "Stock color for the dark theme",
            "when": "${viewport.theme == 'dark'}",
            "colors": {
                "colorTextPrimary": "#f0f1ef"
            "description": "Standard font sizes",
            "dimensions": {
                "textSizeBody": 48,
                "textSizePrimary": 27,
                "textSizeSecondary": 23,
                "textSizeDetails": 20,
                "textSizeSecondaryHint": 25
            "description": "Common spacing values",
            "dimensions": {
                "spacingThin": 6,
                "spacingSmall": 12,
                "spacingMedium": 24,
                "spacingLarge": 48,
                "spacingExtraLarge": 72
            "description": "Common margins and padding",
            "dimensions": {
                "marginTop": 40,
                "marginLeft": 60,
                "marginRight": 60,
                "marginBottom": 40
    "styles": {
        "textStyleBase": {
            "description": "Base font description; set color",
            "values": [
                    "color": "@colorTextPrimary"
        "textStyleBase0": {
            "description": "Thin version of basic font",
            "extend": "textStyleBase",
            "values": {
                "fontWeight": "100"
        "textStyleBase1": {
            "description": "Light version of basic font",
            "values": {
                "fontWeight": "300"
        "textStyleBase2": {
            "description": "Regular version of basic font",
            "values": {
                "fontWeight": "500"
        "mixinBody": {
            "values": {
                "fontSize": "@textSizeBody"
        "mixinPrimary": {
            "values": {
                "fontSize": "@textSizePrimary"
        "mixinDetails": {
            "values": {
                "fontSize": "@textSizeDetails"
        "mixinSecondary": {
            "values": {
                "fontSize": "@textSizeSecondary"
        "textStylePrimary": {
            "extend": [
                "textStyleBase1",
                "mixinPrimary"
        "textStyleSecondary": {
            "extend": [
                "textStyleBase0",
                "mixinSecondary"
        "textStyleBody": {
            "extend": [
                "textStyleBase1",
                "mixinBody"
        "textStyleSecondaryHint": {
            "values": {
                "fontFamily": "Bookerly",
                "fontStyle": "italic",
                "fontSize": "@textSizeSecondaryHint",
        "textStyleDetails": {
            "extend": [
                "textStyleBase2",
                "mixinDetails"
    "onMount": [],
    "graphics": {},
    "commands": {},
    "layouts": {
        "FullHorizontalListItem": {
            "parameters": [
                "listLength"
            "item": [
                    "type": "Container",
                    "height": "100vh",
                    "width": "100vw",
                    "alignItems": "center",
                    "justifyContent": "end",
                    "items": [
                            "type": "Image",
                            "position": "absolute",
                            "height": "100vh",
                            "width": "100vw",
                            "overlayColor": "rgba(0, 0, 0, 0.6)",
                            "source": "${data.image.sources[0].url}",
                            "scale": "best-fill"
                            "type": "AlexaHeader",
                            "headerTitle": "${title}",
                            "headerAttributionImage": "${logo}",
                            "grow": 1
                            "type": "Text",
                            "text": "${data.textContent.primaryText.text}",
                            "speech":"${data.mySpeechData.properties.outputTitle}",
                            "style": "textStyleBody",
                            "maxLines": 1
                            "type": "Text",
                            "text": "${data.textContent.secondaryText.text}",
                            "style": "textStyleDetails"
                            "type": "Text",
                            "text": "${ordinal} | ${listLength}",
                            "paddingBottom": "20dp",
                            "color": "white",
                            "spacing": "5dp"
        "HorizontalListItem": {
            "item": [
                    "maxWidth": 528,
                    "minWidth": 312,
                    "paddingLeft": 16,
                    "paddingRight": 16,
                    "height": "100%",
                    "items": [
                            "type": "Image",
                            "height": "40vh",
                            "width": "40vh"
                            "type": "Text",
                            "text": "<b>${ordinal}.</b> ${data.textContent.primaryText.text}",
                            "style": "textStyleSecondary",
                            "maxLines": 1,
                            "spacing": 12
                            "type": "Text",
                            "style": "textStyleDetails",
                            "spacing": 4
        "ListTemplate2": {
            "parameters": [
                "backgroundImage",
                "title",
                "logo",
                "hintText",
                "listData"
            "items": [
                    "when": "${viewport.shape == 'round'}",
                    "height": "100%",
                    "width": "100%",
                    "items": [
                            "type": "Sequence",
                            "id": "mySequence",
                            "scrollDirection": "horizontal",
                            "data": "${listData}",
                            "height": "100%",
                            "width": "100%",
                            "numbered": true,
                            "item": [
                                    "type": "FullHorizontalListItem",
                                    "listLength": "${payload.listTemplate2ListData.listPage.listItems.length}"
                    "height": "100vh",
                    "width": "100vw",
                    "items": [
                            "type": "Image",
                            "source": "${backgroundImage}",
                            "scale": "best-fill",
                            "width": "100vw",
                            "height": "100vh",
                            "type": "Sequence",
                            "paddingLeft": "@marginLeft",
                            "paddingRight": "@marginRight",
                            "height": "70vh",
                            "width": "100%",
                            "numbered": true,
                            "item": [
                                    "type": "HorizontalListItem"
                            "type": "AlexaFooter",
                            "footerHint": "${payload.listTemplate2ListData.hintText}",
                            "top": "85vh"
    "mainTemplate": {
        "parameters": [
            "payload"
        "item": [
                "type": "ListTemplate2",
                "backgroundImage": "${payload.listTemplate2Metadata.backgroundImage.sources[0].url}",
                "title": "${payload.listTemplate2Metadata.title}",
                "hintText": "${payload.listTemplate2Metadata.hintText}",
                "logo": "${payload.listTemplate2Metadata.logoUrl}",
                "listData": "${payload.listTemplate2ListData.listPage.listItems}"
Data:
        "type": "object",
            "sources": [
                    "size": "small",
                    "widthPixels": 0,
                    "heightPixels": 0
                    "size": "large",
                    "widthPixels": 0,
                    "heightPixels": 0
        "type": "list",
        "listPage": {
            "listItems": [
                    "ordinalNumber": 1,
                    "textContent": {
                        "primaryText": {
                            "text": "Brie"
                        "secondaryText": {
                            "text": "Origin: France"
                    "image": {
                        "sources": [
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "brie",
                    "mySpeechData": {
                        "type": "object",
                        "properties": {
                            "title": "Sam Lee"
                        "transformers": [
                    "listItemIdentifier": "gruyere",
                    "ordinalNumber": 2,
                    "textContent": {
                        "primaryText": {
                            "text": "Gruyere"
                        "secondaryText": {
                            "type": "RichText",
                            "text": "Origin: Switzerland"
                    "image": {
                        "sources": [
                                "url": "https://d2o906d8ln7ui1.cloudfront.net/images/md_gruyere.png",
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "gruyere",
                    "mySpeechData": {
                        "type": "object",
                        "properties": {
                            "title": "Sam Lee"
                        "transformers": [
                    "listItemIdentifier": "gorgonzola",
                    "ordinalNumber": 3,
                    "textContent": {
                        "primaryText": {
                            "text": "Gorgonzola"
                        "secondaryText": {
                            "type": "RichText",
                            "text": "Origin: Italy"
                    "image": {
                        "sources": [
                                "url": "https://d2o906d8ln7ui1.cloudfront.net/images/md_gorgonzola.png",
                                "size": "small",
                                "widthPixels": 0,
                                "heightPixels": 0
                                "size": "large",
                                "widthPixels": 0,
                                "heightPixels": 0
                    "token": "gorgonzola",
                    "mySpeechData": {
                        "type": "object",
                        "properties": {
                            "title": "Sam Lee"
                        "transformers": [
Just modified the template created in developer tool. I issue a SpeakList command which actually scrolls through the list but nothing is spoken.
Your assistance is greatly appreciated as I have an urgent demo tomorrow
Jean Vence answered
    Map<String, Object> document;
        try {
            document = mapper.readValue(new File("List.json"), documentMapType);
            TypeReference<HashMap<String, Object>> dataSourceMapType = new TypeReference<HashMap<String, Object>>() {
            Map<String, Object> dataSource = mapper.readValue(new File("ListData.json"), dataSourceMapType);
            RenderDocumentDirective documentDirective = RenderDocumentDirective.builder().withToken("documentToken")
                    .withDocument(document).withDatasources(dataSource).build();
            List<com.amazon.ask.model.interfaces.alexa.presentation.apl.Command> commands = new ArrayList<>();
            commands.add(SpeakListCommand.builder().withStart(0).withCount(3).withComponentId("mySequence")
                    .withMinimumDwellTime(1000).withAlign(Align.CENTER).build());
            ExecuteCommandsDirective commandsDirective = ExecuteCommandsDirective.builder().withToken("documentToken")
                    .withCommands(commands).build();
            return input.getResponseBuilder().addDirective(documentDirective).addDirective(commandsDirective).build();
        } catch (IOException e) {
            throw new AskSdkException("Unable to read or deserialize karaoke data", e);
As you can see, the component id is "mySequence"
Jean Vence answered
Can anyone shed any light on this? Thanks
Thanks for your patience.
I have created a brand new layout with using "default" components.
It consists of a Sequence of 3 Container(s), each of them containing an Image and 2 Text(s).
Here is the full importable layout:
    "document": {
        "type": "APL",
        "version": "1.1",
        "settings": {},
        "theme": "dark",
        "import":[],
        "resources": [],
        "styles": {},
        "graphics": {},
        "commands": {},
        "layouts": {},
        "mainTemplate": {
            "parameters": [
                "payload"
            "items": [
                    "height": "100vh",
                    "width": "100vw",
                    "items": [
                            "type": "Image",
                            "source": "https://d2o906d8ln7ui1.cloudfront.net/images/LT2_Background.png",
                            "width": "100vw",
                            "height": "100vh",
                            "type": "Sequence",
                            "id": "SequenceToSpeak",
                            "width": "100%",
                            "height": "70vh",
                            "paddingLeft": "20",
                            "paddingRight": "20",
                            "paddingTop": "20",
                            "item": [
                                    "id": "ContainerOne",
                                    "width": "100vw",
                                    "speech": "${payload.newData.properties.ssmlSpeech1_out}",
                                    "height": "100%",
                                    "paddingLeft": "16",
                                    "paddingRight": "16",
                                    "items": [
                                            "type": "Image",
                                            "width": "40vh",
                                            "height": "40vh",
                                            "source": "https://d2o906d8ln7ui1.cloudfront.net/images/md_brie.png"
                                            "type": "Text",
                                            "maxLines": 1,
                                            "text": "Brie",
                                            "spacing": "12"
                                            "type": "Text",
                                            "text": "Origin: France",
                                            "spacing": "4"
                                    "id": "ContainerTwo",
                                    "width": "100vw",
                                    "speech": "${payload.newData.properties.ssmlSpeech2_out}",
                                    "height": "100vh",
                                    "items": [
                                            "type": "Image",
                                            "width": "40vh",
                                            "height": "40vh",
                                            "source": "https://d2o906d8ln7ui1.cloudfront.net/images/md_gruyere.png"
                                            "type": "Text",
                                            "maxLines": 1,
                                            "text": "Gruyere",
                                            "spacing": "12"
                                            "type": "Text",
                                            "text": "Origin: Switzerland",
                                            "spacing": "4"
                                    "id": "ContainerThree",
                                    "width": "100vw",
                                    "speech": "${payload.newData.properties.ssmlSpeech3_out}",
                                    "height": "100vh",
                                    "items": [
                                            "type": "Image",
                                            "width": "40vh",
                                            "height": "40vh",
                                            "source": "https://d2o906d8ln7ui1.cloudfront.net/images/md_gorgonzola.png"
                                            "type": "Text",
                                            "maxLines": 1,
                                            "text": "Gorgonzola",
                                            "spacing": "12"
                                            "type": "Text",
                                            "text": "Origin: Italy",
                                            "spacing": "4"
    "datasources": {
        "newData": {
        "type": "object",
        "properties": {
            "ssmlSpeech1": "Brie",
            "ssmlSpeech2": "Gruyere",
            "ssmlSpeech3": "Gorgonzola"
        "transformers": [
                "inputPath": "ssmlSpeech1",
                "outputName": "ssmlSpeech1_out",
                "inputPath": "ssmlSpeech2",
                "outputName": "ssmlSpeech2_out",
                "inputPath": "ssmlSpeech3",
                "outputName": "ssmlSpeech3_out",
and the SpeakList command to be sent:
                        "type": "SpeakList",
                        "componentId": "SequenceToSpeak",
                        "start": 0,
                        "count": 4,
                        "minimumDwellTime": 1000,
                        "align": "center"
This will let Alexa go through all the elements of the Sequence, and read out loud the content of the "speech" property, so it should be a good fit for your demo.
Back to your question, applying a transformer to a list object should be technically possible, I will update this thread once I get an answer from our internal team.
Kind regards,
Gaetano
