JDCimino avatar image
JDCimino asked ·
How do I connect CloudWatch to an Alexa hosted skill?
I am unable to log my errors to CloudWatch. Is there a tutorial on how to connect my Alexa-hosted skill to CloudWatch?
hosted skill
newuser-e397ab1d-ab75-427d-99d5-a68d01d78d40 avatar image
newuser-e397ab1d-ab75-427d-99d5-a68d01d78d40 answered ·
if you are writing python code use root.info method from library logging
import logging
root = logging.getLogger()
if root.handlers:
for handler in root.handlers:
root.removeHandler(handler)
logging.basicConfig(format='%(asctime)s %(message)s', level=logging.DEBUG)
root.setLevel(logging.INFO)
put this code on start and use roo.info("this will be printed").
Also give cloudwatchlogfullaccess for the role
Amazon_Bernardo Bezerra answered ·
Hello and thanks for your message.
In order to see the logs for your Alexa Hosted Skill, you need to click on the link at the bottom left side of the Code tab in the Developer Console:
Regards,
Barry
7 comments
I am trying the same way. But it is not happening for me. I made the skill via Alexa Inhosted process.
Could you please help.
The specific log group: /aws/lambda/9d2ce4a4-b221-4c49-970d-8c76a1008fd0 does not exist in this account or region.
Amazon_Bernardo Bezerra avatar image Amazon_Bernardo Bezerra ♦♦ newuser-1c3e78e3-e325-45fe-9958-aee9456585eb ·
Hello and thank you for your message.
Can you please provide your skill ID so I can look further into this?
Regards,
Barry
Exactly the same happens to me. I cannot find the logs. The skill ID is 70ceb981-1b22-409b-8d26-b1630cc33f05
newuser-37770487-2e06-44d6-addc-2299101699be avatar image newuser-37770487-2e06-44d6-addc-2299101699be newuser-1c3e78e3-e325-45fe-9958-aee9456585eb ·
I have the same problem because I deleted the file.... :-(
I'm stupid, very stupid. I only wanted space was liberated and I missed this functionality.
