newuser-60f46086-7b81-4dbe-8b5d-98c21e6d0f78 avatar image
smart home skill delete device problem
I have developed a smart home light skill with the lambda function. I have used IOS Alexa app to enable the skill and has discovered the devices successfully. However, I found that after I press the "trash bin "logo in the Alexa App (shown in below graph) to delete the device, the device cannot be deleted. How can I modify the skill or lambda function so that the delete devices in the Alexa App can be succeeded
alexa smart home
apeksha avatar image
apeksha answered
Hello there,
Please follow the steps below to delete discovered devices:
Step1: Login to the Alexa web app.
Step2: Under 'menu' go to the "Smart Home" section you can see Groups, Devices and Scenes options.
Step 3: Now click on "Devices" and do "Forget all" and you will receive a pop up please select "Forget", in order to delete all the discovered devices. You can also click on the "forget" button in front of the each endpoint to delete particular endpoint.
