newuser-ef06051c-7aa1-4dd5-bc43-5bdac6ef77d6 avatar image
IAP in Live App Testing gives error
Hi, I am implementing IAP in my app. I am using sample that comes in Amazon SDK for inAppPurchase. In local i am using app tester and its working fine but its not working with Live App testing. giving some error. I have already created in app item on Amazon portal. Below is the error which i am facing -
javax.crypto.IllegalBlockSizeException: last block incomplete in decryption
at com.android.org.bouncycastle.jcajce.provider.symmetric.util.BaseBlockCipher.engineDoFinal(BaseBlockCipher.java:1104)
at javax.crypto.Cipher.doFinal(Cipher.java:2056)
at com.amazon.mas.client.util.encryption.SimpleObfuscator.deobfuscate(SimpleObfuscator.java:381)
at com.amazon.mas.client.util.encryption.SimpleObfuscator.deobfuscate(SimpleObfuscator.java:120)
at com.amazon.mas.client.iap.datastore.IAPCheckpointTable.getCheckpoint(IAPCheckpointTable.java:167)
at com.amazon.mas.client.iap.datastore.IAPDataStoreImpl.getCheckpoint(IAPDataStoreImpl.java:346)
at com.amazon.mas.client.iap.subscription.SubscriptionsManagerImpl.sync(SubscriptionsManagerImpl.java:184)
at com.amazon.mas.client.iap.purchasehistory.PurchaseHistoryManagerImpl$3.run(PurchaseHistoryManagerImpl.java:169)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
at java.lang.Thread.run(Thread.java:761)
iaplive app testing
Levon@Amazon avatar image
Levon@Amazon answered
Hi there,
It sounds like a configuration problem, possibly ProGuard or another code obfuscator (such as the new R8 in the latest Android Studio) interfering and stripping parts of your code as you export your app for release.
To test that, please either disable ProGuard / R8 before you upload the next beta version to Live App Testing, or configure it to exclude / ignore certain classes, and see if IAP works for you. For that, please see this article on how to configure ProGuard for Amazon IAP: https://developer.amazon.com/docs/in-app-purchasing/iap-obfuscate-the-code.html -- thanks!
6 comments
@Levon@Amazon Thanks for your answer. I did that but still facing the issue. Please have a look below attached screenshot. https://drive.google.com/open?id=1R19L7bqOM8xG9YbvfOCpLMyaiAIKOft1 also have a look to below logs - https://drive.google.com/open?id=18opn5cSR-R-UTZxoIJ-iQfFq89zsbHdT
newuser-ef06051c-7aa1-4dd5-bc43-5bdac6ef77d6 avatar image newuser-ef06051c-7aa1-4dd5-bc43-5bdac6ef77d6 newuser-69388ee6-68a8-4f23-97d8-08195ed03ea0 ·
I am still facing the issue in IAP. Please have a look to below logs -
https://docs.google.com/document/d/18f4IcSEGOvB-3D2ZFuPHC2KfOL-aU_G44aHKuHLGsh4/edit?usp=sharing
Please help me , I am stuck at this point.
2 Likes 2 ·
newuser-a1e66e9a-df0f-4a34-8428-946459a493c8 avatar image newuser-a1e66e9a-df0f-4a34-8428-946459a493c8 newuser-ef06051c-7aa1-4dd5-bc43-5bdac6ef77d6 ·
Hey, I am having the same issue, how did you solve it?
newuser-ef06051c-7aa1-4dd5-bc43-5bdac6ef77d6 answered
newuser-a1e66e9a-df0f-4a34-8428-946459a493c8 answered
The issue happening turned out to be from Amazon LAT not working saying "An error occurred while processing your purchase" -> An error occurred while attempting to purchase this item please try again."
When I uploaded same code to production it worked!
WhiteXmasBone avatar image
WhiteXmasBone answered
So the solution is to simply ignore LAT and just try production? :-)
newuser-94224243-d73d-44a4-867a-b7507db26cef avatar image
newuser-94224243-d73d-44a4-867a-b7507db26cef answered
any solution
can anyone briefly explain solution to this problem ! ?????
newuser-def31457-c9b3-4fed-85a5-234cc41df4a1 avatar image
newuser-def31457-c9b3-4fed-85a5-234cc41df4a1 answered
Hi ,
I am also getting same issue in LAT
screen short:here
and log :here
