atlars avatar image
atlars asked
Get GraphQL query with NodeJS
I'm new to Node.JS and GraphQL. I need to add a GraphQL query to the getRemoteData function below.
GraphQL query:
  query {
      posts (first: 10) {
        edges {
          node {
            id
            name
getRemoteData Handler:
const GetRemoteDataHandler = {
  canHandle(handlerInput) {
    return handlerInput.requestEnvelope.request.type === 'LaunchRequest'
      || (handlerInput.requestEnvelope.request.type === 'IntentRequest'
      && handlerInput.requestEnvelope.request.intent.name === 'GetRemoteDataIntent');
  async handle(handlerInput) {
    let outputSpeech = 'This is the default message.';
    await getRemoteData('https://example.com/api/graphql')
      .then((response) => {
        const data = JSON.parse(response);
        outputSpeech = `... `;
getRemoteData:
  const getRemoteData = function (url) {
      return new Promise((resolve, reject) => {
        const client = url.startsWith('https') ? require('https') : require('http');
        const request = client.get(url, (response) => {
          if (response.statusCode < 200 || response.statusCode > 299) {
            reject(new Error('Failed with status code: ' + response.statusCode));
          const body = [];
          response.on('data', (chunk) => body.push(chunk));
          response.on('end', () => resolve(body.join('')));
        request.on('error', (err) => reject(err))
How to add a GraphQL query to the getRemoteData function?
Any help is really appreciated, thank you.
alexa skills kitalexaapinodejsrequest
Rokas avatar image
Rokas answered
I haven't worked too much with graphql myself, so I don't know if there is native methods in node to do a graphql request, but I would probably use this package: here. It has an example how to use graphql queries.
One more thing, you don't need to await a promise, that you use then() on, at line 10 in first example.
Thank you, graphql-request seems the way to go. I posted a follow up question here: https://forums.developer.amazon.com/questions/207898/graphql-query-in-nodejs-fails-with-there-was-a-pro.html Any help is really appreciated
