salazarpresentys avatar image
salazarpresentys asked
can I remove the opacity from APL?
I would like to know how to remove the opacity which is set by default in the APL template which is similar to List Template 2.
Thanks in advance.
alexa skills kitalexalambdaaplnode_js
sungyoo avatar image
sungyoo answered
Hey @salazarpresentys can you explain what you mean by APL template? Do you have an example within a JSON where you want to remove opacity?
salazarpresentys answered
Hi @Oliver@Amazon, I should have been more specific about APL template.
I am developing a front-end for my skill which is invoked on Echo's which have display. The front-end is being developed using the Display Beta section in the Alexa Developer Console and Alexa Presentation Language (APL) [1]
Display Beta section, makes available some templates which makes reference to Display Interface [2] templates.
I am using one of this APL "templates", concretly, the similar toList Template 2 (Display Interface).
In this template, a set of pictures are showed with an opacity seted by default. Could I remove or decrease this opacity? Even if the json template doesn't have a specific opacity property.
Kind regards.
[1] https://developer.amazon.com/docs/alexa-presentation-language/apl-overview.html
[2] https://developer.amazon.com/docs/custom-skills/display-interface-reference.html
Amazon_Bernardo Bezerra avatar image Amazon_Bernardo Bezerra commented ·
Hello @salazarpresentys and thank you for your message.
Are you still trying to find a solution for this? According to the documentation, here and here, there are ways of setting the opacity of items in your template.
Regards,
Barry
