atlars avatar image
atlars asked
Help me to setup the Alexa skill sample "nodejs-audio-player" for multiple streams
I need to get the official Alexa skill sample "nodejs-audio-player multiple-streams" to work as a custom skill and Alexa Hosted . https://github.com/alexa/skill-sample-nodejs-audio-player
A step by step guide to set this up would be really appreciated.
audioaudioplayernode_jsnodejsjavascript
Hi @atlars and thanks for your message.
You can create a Alexa hosted skill in the developer portal, enable the Audio Player interface under the "Interfaces" section and then copy and paste the interaction model and code.
Regards,
Barry
4 comments
I did that but it's not working. Can you please send me a screenshot of the folder structure?
Hello @atlars,
The folder structure should be the same one as shows in the repository, i.e. https://github.com/alexa/skill-sample-nodejs-audio-player/tree/mainline/single-stream
While I did mention in my message that you should copy and paste, it isn't as simple as that. There are some precautions that you must take, specially when updating the code.
In terms of the code, my suggestion would be for you to just replace/add the handlers. Also, make sure to take a look at the logs at Cloudwatch to have a better view of what might be happening. Remember,
console.log()
is your friend.
Regards,
Barry
gabbiano69 avatar image gabbiano69 Amazon_Bernardo Bezerra ♦♦ ·
same problem with alexa host skill, i cop the cde but noy run
gabbiano69 answered
this is the log message:
Unable to import module 'index': Error
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Module.require (module.js:596:17)
at require (internal/module.js:11:18)
