newuser-5b958b72-d988-4b09-aac3-c1f59f0940a2 avatar image
newuser-5b958b72-d988-4b09-aac3-c1f59f0940a2 asked ·
Raspberry Pi freezes on AVS install
I'm going through the Amazon Developer tutorial on how to install the AVS onto a Raspberry Pi. I've followed the instructions up until "Build the AVS Device SDK." I entered the commands and after a few minutes and a prompt, the whole thing freezes at:
[ 59%] Building CXX object CapabilityAgents/Bluetooth/src/CMakeFiles/Bluetooth.dir/Bluetooth.cpp.o
The processor gets really hot and I had to cut the power. Am I doing anything wrong? I've looked at other forum posts with similar issues but none offer any solutions I can use. I'm using an updated Raspberry Pi 3 B+. Any help would be appreciated!
alexa voice servicealexa
2 comments
I’m having the same issues, I rebooted at the point your having issues and restarted and it got as far as 95% but freezing there now and have rebooted several times now but can’t get passed that, hope someone can provide a fix.
The RaspberryPi may get over heated during the compilation of the SDK. I suggest trying to use "make SampleApp" instead of "make -j2 SampleApp" and make sure there's plenty of ventilation around the RaspberryPi and try again.
newuser-64a8c6de-7dd8-4c9f-b294-48d6008a91ec avatar image
newuser-64a8c6de-7dd8-4c9f-b294-48d6008a91ec answered ·
I have the same issues, mine freezes at 97% when it's building CXX object ......
Any help is appreciated, thanks!
2 comments
I have the same issue u had.. did you find a solution ?
i have same issue!
JCML avatar image
JCML answered ·
For me it was the same, shutdown + reboot and make a new compilation will resolve this.
sammy avatar image
sammy answered ·
I found that as well as removing the -j2, increasing the swap file size from 100 to 1024 stopped the problem.
Could someone elaborate on this? I haven't used any command that looks like this so I'm not sure where to edit this...
newuser-0f5f0d99-8eab-4258-b7a6-e49b4609ba25 avatar image
newuser-0f5f0d99-8eab-4258-b7a6-e49b4609ba25 answered ·
I solved this problem closing every this on my screen unleash the Terminal.
In this step, is required lot of system memory, i saw on task.
If this procedure not fix the problem, change you swap memory size.
To do this fallow this instruction on terminal:
sudo -s
swapoff -a
dd if=/dev/zero of=/swapfile bs=1M count=512
mkswap /swapfile
swapon /swapfile
swapon -s
That last one shows if the size change to more than 524000.
This procedure taked a 1:30 hour to be completed.
I hope helped you.
