onRegistered and other methods are called fine.
I am using SNS to publish the ADM message. After I receive and log the registrationId in the onRegistered callback, I manually create the SNS platform endpoint with the registrationId,.
When I publish the message via SNS it shows a 200, however the onMessage callback is not triggered. If, from my fire tablet's settings I click "sync device", I can see my ADM receiver picking up the message and things work as expected. I have run
ADMManifest.checkManifestAuthoredProperly
and it does not return any issues. Given that upon sync everything works together this tells me that my manifest and receiver should be set up correctly.
I can receive ADM messages from other applications on the device, and my application does have an assets folder with the api_key.txt without any spaces.
My manifest looks like so (applicationId defined in a different manifest):
<?xml version="1.0" encoding="utf-8"?> <manifest xmlns:android="http://schemas.android.com/apk/res/android" xmlns:amazon="http://schemas.amazon.com/apk/res/android" package="com.test.testnotification"> <!-- This permission ensures that no other application can intercept your ADM messages. --> <permission android:name="${applicationId}.permission.RECEIVE_ADM_MESSAGE" android:protectionLevel="signature" /> <uses-permission android:name="${applicationId}.permission.RECEIVE_ADM_MESSAGE" /> <!-- This permission allows your app access to receive push notifications from ADM. --> <uses-permission android:name="com.amazon.device.messaging.permission.RECEIVE" /> <!-- ADM uses WAKE_LOCK to keep the processor from sleeping when a message is received. --> <uses-permission android:name="android.permission.WAKE_LOCK" /> <application android:allowBackup="true"> <provider android:exported="false" android:name=".provider.InitProvider" android:authorities="com.test.testnotification.provider.InitProvider" /> <service android:name=".service.RegistrationService" android:exported="false"/> <!-- ADM is required for this library to be used --> <amazon:enable-feature android:name="com.amazon.device.messaging" android:required="true" /> <!-- Service which handles messages sent by ADM. <service android:name=".service.NotificationService" android:exported="false"/> <!-- ADM requires the receiver to be defined in manifest rather than programmatically --> <receiver android:name=".receiver.NotificationReceiver" android:permission="com.amazon.device.messaging.permission.SEND"> <!-- To interact with ADM, you must listen for the following intents. --> <intent-filter> <action android:name="com.amazon.device.messaging.intent.REGISTRATION" /> <action android:name="com.amazon.device.messaging.intent.RECEIVE" /> <category android:name="${applicationId}" /> </intent-filter> </receiver> </application> </manifest>
I am not sure what needs to be changed to have the broadcast receiver triggered immediately?
