I am developing an Alexa Skill using nodeJS 10 and lambda function as endpoint backend.
I am trying to call Rest Api (with GET method) on lambda function using nodeJS, but i am having difficulties because of execution time on lambda function. I have exported my lambda function with a deployment package in order to develop using VSCode and I have installed 'request' npm package (https://www.npmjs.com/package/request) and I am the code does the following:
the function which implements the calling.
function GetMedicamento(){ var request = require('request'); var response = request.get('https://cima.aemps.es/cima/rest/medicamento?cn=754614', {json: true }, (err, res, body) => { if (err) { return console.log(err); } console.log(body.url); console.log(body.explanation); }); return response; }
the function which playing the calling. _ I only have a console.log() with the api calling because I want to make sure the response is good.
const BuscaMedicamentoHandler = { canHandle(handlerInput){ const request = handlerInput.requestEnvelope.request; return request.type === 'IntentRequest' && request.intent.name === 'BuscaMedicamentoIntent'; }, handle(handlerInput){ console.log(GetMedicamento()); var number = handlerInput.requestEnvelope.request.intent.slots.numero.value; speechOutput = "Código nacional: " + number; return handlerInput.responseBuilder .speak(speechOutput) .reprompt(speechOutput) .getResponse(); } };
The lambda function is playing the calling (I have the certainty because I can see that in the cloudwatch logs) but the response come back with a null body, so I cannot do nothing. I said 'execution time' because I think that the problem could be that I need to use an 'async'-'await' clauses or 'promises' but I don't have many experience developing in nodeJS.
could someone let me see an example of implementing that funtionality?
thanks in advance,
Pedro.
