Aditya.B avatar image
Aditya.B asked
Accessing a .csv file stored in AWS S3 through Lambda function (Node Js)
A .csv file is stored in AWS S3. I want to access it through Lambda function coded in NodeJs.
If there are 3 columns in .csv file, and the user gives the values of 2 attributes, then the alexa should return the value of 3rd attribute. The lambda function should search .csv file in S3 and return the required value from the row.
Please help.
A sample NodeJs code would help.
alexa skills kitlambdaaws
Robert G Schaffrath avatar image
Robert G Schaffrath answered
One option you can consider is the S3 selectObjectContent function. It allows you to issue simple SQL queries against a CSV (or JSON) file in S3 and return the results. In your case, you could select against criteria matching columns 1 and 2, and return the value in column 3. Something along the lines of:
select _3 from S3Object where _1 = condition1 and _2 = condition2
There is documentation at:
https://docs.aws.amazon.com/AmazonS3/latest/API/RESTObjectSELECTContent.html
The Node documentation on the function is at:
https://docs.aws.amazon.com/AWSJavaScriptSDK/latest/AWS/S3.html#selectObjectContent-property
Aditya.B avatar image Aditya.B commented ·
Thank you for your Response.
I am getting an error and I cannot understand what the error is.
This is my code after adding the S3 logic :
'KpiIntent': function () {
const s3 = require('aws-sdk/clients/s3');
let filledSlots = delegateSlotCollection.call(this);
speechOutput = '';
let Machine_typeSlot = resolveCanonical(this.event.request.intent.slots.Machine_type);
console.log(Machine_typeSlot);
let dateSlot = resolveCanonical(this.event.request.intent.slots.date);
console.log(dateSlot);
let placeSlot = resolveCanonical(this.event.request.intent.slots.place);
console.log(placeSlot);
let Crew_typeSlot = resolveCanonical(this.event.request.intent.slots.Crew_type);
console.log(Crew_typeSlot);
let productSlot = resolveCanonical(this.event.request.intent.slots.product);
console.log(productSlot);
var params = {
Bucket: 'bucket_name', /* required */
Expression: 'select avg from S3Object where product=productSlot and unit=placeSlot and date=dateSlot and crew=Crew_typeSlot and machine=Machine_typeSlot',
ExpressionType: 'SQL', /* required */
InputSerialization: { /* required */
CSV: {
FieldDelimiter: ',',
FileHeaderInfo: 'USE',
RecordDelimiter: '\n'
Key: 'key', /* required */
OutputSerialization: { /* required */
CSV: {
s3.selectObjectContent(params, function(err, data) {
if (err) console.log(err, err.stack); // an error occurred
else {console.log(data);
speechOutput=data;
}// successful response
//speechOutput = "KPI INTENT";
this.emit(':ask', speechOutput, speechOutput);
