calleu avatar image
calleu asked
Public Alexa Flash Briefing with ASK SDK
Hi Guys ! I'm New in Alexa Skill Development, sorry for the noob question, but I did not found in Anywhere about that.
I have an application with provide a JSON in S3 with some flash briefing content. If i go to Developer console and create skill manually and set that JSON , the flash briefing skill works normally in ALEXA device.
But I need to go to Developer console and manually create a flash briefing skill and associate the JSON to this. But what i want is automate this process. Anyone know if has any way to automate this process with Node ASK SDK?
I want to automate this process and send to Review process.
If anyone cal help me I'm grateful
Thanks Guys
skillflash briefingask clinode_jssdk v2
Gaetano@Amazon avatar image
Gaetano@Amazon answered
Hello!
thanks for your interest in Alexa skills development.
You can automate the flash briefing creation process by setting up the ASK-CLI, which supports all the commands you need.
How to setup the ASK-CLI:
https://developer.amazon.com/docs/smapi/quick-start-alexa-skills-kit-command-line-interface.html
After you get everything set up, follow these steps:
- Manually create your Flash Briefing skill and test it
- Launch the ask clone command and select your freshly made Flash Briefing skill:
- A new folder with the Skill name will be created, point your terminal in it with the cd command
- Delete the skill_id and eTag values from the .ask/config file
- Edit the name (name of your skill) and url (Feed URL) key values from the skill.json file
- Run the ask deploy command
You will now find a new skill into your developer portal. If you want to proceed with the skill submission, please check the "submit" command from the following reference:
https://developer.amazon.com/docs/smapi/ask-cli-command-reference.html
Kind regards,
Gaetano
Hi Gaetano!
Thx for the answer! I will gona try this!
