newuser-ff8ddec0-d080-4a04-8192-c1f19d90bbf3 avatar image
Flash Briefing question
Hello, I am new to Alexa and am not sure what this means. I created a couple Flash Briefings to test how they work. Recently I created a Flash Briefing from an RSS feed I built and it all appeared to create fine. However, when I test it, Alexa says, "where should I get your news from".
When I created my first Flash Briefings from other RSS feeds a month or so ago, they seemed to work fine, but when I go back to test them now , I get the same alexa asking "where should I get your news from".
Is this an error in my flash briefing setup, or What is this telling me?
Thank you,
Mark
flash briefing
Gaetano@Amazon avatar image
Gaetano@Amazon answered
Hi Mark!
thanks for posting on our forums.
Your RSS feed is probably expired: Alexa ignores all the items with a date older than 7 days. Date must be in the YYYY-MM-DDThh:mm:ssZ format.
Flash Briefing feed reference here.
If updating the date in your feed doesn't solve the issue, please share the Skill-ID and the feed url.
Kind regards,
Gaetano
