TommyS avatar image
TommyS asked
Error trying to use MonetizationServiceClient
I am trying to use MonetizationServiceClient with Java SDK.
Attempting to use service client factory with no configured API client.
When I do:
MonetizationServiceClient client = input.getServiceClientFactory().getMonetizationService();
InSkillProduct product = client.getInSkillProduct("en-EN", "myid");
I am receiving:
java.lang.IllegalStateException: Attempting to use service client factory with no configured API client
What to I need to do in order to configure this API client?
Thanks!
javaisp
Hi @TommyS and thanks for your post.
I used the sample code from the Alexa official GitHub repository over here to create and deploy a skill implementing ISP. The only difference I could see is that the sample uses the final keyword before declaring the client and product.
If you still encounter this problem after checking that code, feel free to share a bigger snippet of yours so I can help you better.
If you are not comfortable sharing your code in this open forum, you can always open a ticket with us in the alexa.design/contactus page. If you do so, please make sure to reference this thread.
Regards,
Barry
kagey avatar image
kagey answered
en-EN isnt a valid locale. You should pull the user's locale from the input request. I've come across scenarios where the monetization service throws exceptions, i just prentend that purchases aren't available if that happens.
