I'm implementing the new ISP feature but I can't get it to work in the alexa dev console. The refusal of buying is returning a fine answer and I get the declined message. Here is the code I use to get the purchase, and then I'm always getting the following
resolve(handlerInput.responseBuilder .addDirective({ type: "Connections.SendRequest", name: "Upsell", payload: { InSkillProduct: { productId: "###my-product-ID###", }, upsellMessage: "Would you like to buy my product?", }, token: "my-correlation-token", })
"request": { "type": "Connections.Response", "requestId": "amzn1.echo-api.request.1da4e7a3-8be1-4a09-8b56-5cb590db08f4", "timestamp": "2019-03-04T03:16:13Z", "locale": "en-US", "status": { "code": "400", "message": "BAD REQUEST" }, "name": "Buy", "payload": { "message": "This feature is not supported." }, "token": "correlationToken" }
The documentation does mention shouldEndSession. I added this property as well but got the same result.
I'm not sure if this is related to my amazon dev account which might be a Canadian one. Where could I check that?
