Hey
My skill is to make Alexa remember where I have stored personal belongings using DynamoDB. It's basically like an inventory.
I'm using the ask-sdk standard package and node js 8.10
I used .withTableName('PlaceandThing') and .withAutoCreateTable(true) to create the table. Is this the right method? I'm pasting my Lambda handler below
const skillBuilder = Alexa.SkillBuilders.standard(); exports.handler = skillBuilder .addRequestHandlers(LaunchRequestHandler, AddThingsIntentHandler, TellIntentHandler, HelpIntentHandler, CancelAndStopIntentHandler, SessionEndedRequestHandler, ) .addErrorHandlers(ErrorHandler) .withTableName('PlaceandThing') .withAutoCreateTable(true) .lambda();
I'm unable to even launch the skill. The error I get is as follows,
{ "errorMessage": "Alexa.SkillBuilders.standard is not a function", "errorType": "TypeError", "stackTrace": [ "Module._compile (module.js:652:30)", "Object.Module._extensions..js (module.js:663:10)", "Module.load (module.js:565:32)", "tryModuleLoad (module.js:505:12)", "Function.Module._load (module.js:497:3)", "Module.require (module.js:596:17)", "require (internal/module.js:11:18)" ] }
I have configured two intents : AddThingsIntent which adds the values to the table and TellIntent which reminds the user where the items are stored. The intent handlers are as below,
const AddThingsIntentHandler = { canHandle(handlerInput) { return handlerInput.requestEnvelope.request.type === 'IntentRequest' && handlerInput.requestEnvelope.request.intent.name === 'AddThingsIntent'; }, handle(handlerInput) { var ThingName = handlerInput.requestEnvelope.request.intent.slots.ThingName.value; var PlaceName = handlerInput.requestEnvelope.request.intent.slots.PlaceName.value; const attributes = handlerInput.attributesManager.getSessionAttributes(); if(attributes.Place === undefined){ attributes.Place = {}; } attributes.Place[ThingName] = PlaceName; const speechText = "I will remember that your " + ThingName + "is/are in/on your " +PlaceName; return handlerInput.responseBuilder .speak(speechText) .reprompt(speechText) .withSimpleCard('Reminder Skill', speechText) .getResponse(); } }; const TellIntentHandler = { canHandle(handlerInput) { return handlerInput.requestEnvelope.request.type === 'IntentRequest' && handlerInput.requestEnvelope.request.intent.name === 'TellIntent'; }, handle(handlerInput) { var speechText = ""; var ThingName = handlerInput.requestEnvelope.request.intent.slot.ThingName.value; const attributes = handlerInput.attributesManager.getSessionAttributes(); if(attributes.Place[ThingName]) { speechText = 'Your' + ThingName + 'is/are in/on ' +attributes.Place[ThingName]; } else { speechText = "I don't know where your " +ThingName + "is/are"; } return handlerInput.responseBuilder .speak(speechText) .reprompt(speechText) .withSimpleCard('Reminder Skill', speechText) .getResponse(); } };
I've added the table in DynamoDB manually and tried too. Should I use the DynamoDB Persistence Adapter? What should I do now? Any help is welcome.
