newuser-ad67e4bd-8ba6-402f-afd4-981013ce35f2 avatar image
window.AmazonIapV2 intermittently undefined
I am testing a html5 web app on a FireTv device, I've included both the necessary scripts from the example :
https://resources.amazonwebapps.com/v1/latest/Amazon-Web-App-API-tester.min.js
https://resources.amazonwebapps.com/v1/latest/Amazon-Web-App-API.min.js
However, the global window.AmazonIapV2 intermittently evaluates to undefined and window.AmazonIapV2.addListener errors out.
It is as if the IAP v2 script is not injected in.
Is there a temporal limit set on the request by IP from test devices ?
if (window.AmazonIapV2 === null) {
else {
   window.AmazonIapV2.addListener('getUserDataResponse', function(resp) {});
   window.AmazonIapV2.addListener('getProductDataResponse', function(data) {});
   window.AmazonIapV2.addListener('purchaseResponse', this.onPurchaseResponse);
   window.AmazonIapV2.addListener('getPurchaseUpdatesResponse',this.onPurchaseUpdatesResponse);
iapfire tvpurchasing
Levon@Amazon avatar image
Levon@Amazon answered
Hi there,
Apologies for a late response. If you still have issues, please refer to the latest documentation: https://developer.amazon.com/docs/in-app-purchasing/iap-example-webapp.html
The issue may have been that the listeners have to be added on amazonPlatformReady:
document.addEventListener('amazonPlatformReady', function() {
    // Ensure we can call the IAP API
        console.debug('Amazon In-App-Purchasing only works with Apps from the Appstore');
    } else {
        window.AmazonIapV2.addListener('getPurchaseUpdatesResponse', this.onPurchaseUpdatesResponse);
}.bind(this));
4 comments
A new version of Web App Tester was successfully published to all devices, including Fire OS 7 devices. Thanks!
Hi @Levon@Amazon
Could you comment on Web App Tester not being available on Fire OS 7 devices (e.g., Cube gen 2, Fire HD 10 tablets). Is there a hope that it will be updated to run on those devices? Without it development for those devices rather suck.
Thank you, Jacek
Hi Jacek,
Thanks for bringing it to our attention. I asked the web team to check that. Thanks!
-1 Like -1 ·
Jacek avatar image Jacek Levon@Amazon ♦ ·
Hi @Levon@Amazon
It has been a couple of [weeks] months since you asked the web team. Did you receive any answer? Can you ask about the current status, maybe ETA?
