Unable to place question mark when using SSML at end of Alexa prompt confirmation?
Please help or fix, thanks!
This worked in my testing console:
<speak>
Is
<say-as interpret-as="telephone">1234567</say-as> correct?
</speak>
I think in your second image you got it almost right, but probably it needs a space between the </speak> and the question mark that follows it. More info can be found here:
It seems that there is a problem with speak tags. I also get this error, when I add speak tags. Without them, I was able to put question mark. But if I add ssml and speak tags, I get the error saying, that question mark has to be at the end of the expression. This happens when pressing the plus symbol. Before there is no error:
After pressing plus:
Without ssml it works fine with this example: "I like MG?"
This is still an issue. Alexa's reading punctuation even when it's outside the <say-as> tags.
Check out my Slot Confirmation Alexa Speech Prompt in my SaveBusStopIntent:
I found a solution. You have to use a comma not a period after the </say-as> end tag.
for example: <speak>is <say-as interpret-as="digits">{bus_stop}</say-as>, is that right?</speak>. (works without reading punctuation).
this will read the punctuation:
<speak>is <say-as interpret-as="digits">{bus_stop}</say-as>. is that right?</speak>.
(will read "dot")
My best guess is that there's a regex that's parsing the "." and "?" into SSML but not ",".
3 People are following this question.
