newuser-0b843261-1017-4ac2-96e0-c80f25b1512b avatar image
Save Failed at setting ending point.
i am new in developing skills for echo systems. Everything works finde so far. But at setting the Endingpoint, the builder always shows
----------------------Save Failed
custom.endpoint - No endpoint is defined. Error code: SkillManifestError
I already set the lambda and nearly finished the code. Only a function is missing (its not a required function). I also set the "Alexa Skill Kit". Lamba is set to the correct location: EU (Ireland), i paste the ARN to the "EU & India" text field. I have not idea what i did wrong, Is there maybe a temporarily problem with the communication?
Skill - ID: amzn1.ask.skill.39b65388-dd34-4fcd-801e-bd48909d2832
Thank you in advance
- Xariif
alexa skills kitlambdaechoskill builder
Tsuneki@Amazon avatar image
Tsuneki@Amazon answered
Hi there,
Thanks for posting.
You also need to set the default endpoint, so make sure you've entered the Lambda ARN there as well in the endpoint settings.
