Seth avatar image
Seth asked
AWS IoT SDK used inside Lambda function - no error but payload is not published
I have built an Alexa skill that invokes an AWS IoT object to publish a payload to a specific topic - but I do not see any payloads published from within the Test section of the AWS IoT dashboard.
  1. The skill successfully exits when tested - no errors indicated anywhere inside the code.
  2. After the skill exits a test, I don't see the payload in the Test area of the AWS IoT dashboard
    1. The IoTData object is initialized without any errors:
      var AWS = require('aws-sdk');
      var iotdata = new AWS.IotData({endpoint: '************.iot.us-west-2.amazonaws.com'});
    2. I receive no errors from the following code:
      var params = {
                  topic: 'b827ebac1bba/commands',
                  payload: '0',
                  qos: 0
              iotdata.publish(params);
  3. The IAM policy role attached to the Lambda function allows iot:Publish:
  4. {
        "Version": "2012-10-17",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "logs:CreateLogStream",
                    "logs:PutLogEvents"
                "Resource": "arn:aws:logs:*:*:*"
                "Effect": "Allow",
                "Action": "iot:Publish",
                "Resource": "*"
                "Effect": "Allow",
                "Action": "logs:CreateLogGroup",
Any idea on what I should try next?
lambdaaws iot
Seth avatar image Seth commented ·
UPDATE: When I include a callback function:
iotdata.publish(params, function (err, data) {
            if (err) console.log(err, err.stack); // an error occurred
            else     console.log(data);           // successful response
        });<br>
the lambda function runs until it times out. Also, I have increased the timeout period to 30 seconds.
Jason@Amazon avatar image
Jason@Amazon answered
As this issue is more related to AWS than Alexa, I would suggest posting on the AWS developer forum for further assistance over here.
