subIT avatar image
subIT asked
Check Alexa Display-Support of the APL - Interface
I wanted to check if the Alexa-Device supports a Display with the APL (Alexa Presentation Language).
The problem I have is that - in the last row in the image - the Interfaceword ALEXA_PRESENTATION_LANGUAGE doesn´t work. So when I return true -> Display works, Dot not, and when I return false -> Display didn´t work, Dot does.
So the problem should be the Interfaceword to check.
alexa skills kitaplalexa presentation language
Rokas avatar image
Rokas answered
Here you can find a function to check if display or APL is supported: link.
TL;DR; change 'ALEXA_PRESENTATION_APL to ['Alexa.Presentation.APL'] and it should be good to go.
