Kris B avatar image
Kris B asked
Can we use Proguard
I posted this question in this thread here: https://forums.developer.amazon.com/forums/thread.jspa?messageID=3228&tstart=0 but can we not obfuscate our code using Proguard if we are using Amazon's ads? I ask because on this page: https://developer.amazon.com/sdk/mobileads/event-tracking-and-errors.html It says: "Your ‘R’ class could not be read because it does not have the same name as your package. If your app is obfuscated, please remove obfuscation or ensure that the resource class is not renamed."
mobile ads
Matt15@Amazon avatar image
Matt15@Amazon answered
Hey Kris, The current version of the Amazon Mobile Ads API does not officially support ProGuard obfuscation, but it may still work as long as you ensure the R class retains its name during the obfuscation process. If this doesn't work then the only option is to remove obfuscation. Does this answer your question? Matt
Kris B avatar image
Kris B answered
Sort of. I just have to figure out how to retain the R classes. Not sure how to do that.
Kris B avatar image
Kris B answered
If anyone has figured out how to retain the resources files while using Proguard, please let me know. This is what I've tried so far: -keeppackagenames com.app.*.R; -keepclassmembers com.app.*.R; -keep class com.app.*.R; -keepclassmembers class **.R$* { public static ; }
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Kris,
Thank you for the post. Can you try following proguard options?
-keep public final class **.R$*
    public static ;
-keepclassmembers class **.R {
    public static final class *;
javac generates separate .class files for inner classes that exist in main class (R in this case). So you need to apply the skip obfuscation rule for proguard for all the classes generated after compilation. Let us know if this resolves your issue.
Peter avatar image
Peter answered
I use the following and it works ok for me: -keep class com.amazon.device.ads.** { *; } -keep class **.R { } -keep class **.R$* { } -keepattributes *Annotation*
Hello Peter, Thank you for sharing the proguard rule with us. The currently available Amazon Mobile Ads API, version 5.0.2, now allows the R class to be obfuscated. So developers are not supposed to write any proguard rule to keep the R file intact.
monocube avatar image
monocube answered
Hello, just tried to use Proguard using the latest Android Tools and Amazon Mobile Ads SDK (amazon-ads-5.1.14). I get this: [b]Warning: com.amazon.device.ads.MraidAssets: can't find referenced class org.apache.commons.codec.binary.Base64[/b] Also, if you target Android SDK 18, you also get this: [b]Warning: com.amazon.device.ads.HtmlRenderer: can't find referenced method 'void setPluginsEnabled(boolean)' in class android.webkit.WebSettings Warning: com.amazon.device.ads.MraidView: can't find referenced method 'void setPluginsEnabled(boolean)' in class android.webkit.WebSettings[/b] Can you please help? Message was edited by: monocube
Hi Monocube, Are all these causing failure of Ad loading? Are you getting any error code or reason in logcat?
monocube answered
No, these are caused when exporting the APK from Eclipse - they are logs from Proguard output. Your library seems to be missing some dependency and it's not fully compatible with Android 4.3 (SDK 18). Basically, we can't export and obfuscate the app because of this. Message was edited by: monocube
Hi Monocube, Thanks for bringing the issue into our notice. I have forwarded your issue to the concerned team. Please wait till my next post.
