Christian avatar image
Christian asked
Devices not listed in Routines
We are experimenting with Routines and like to use devices as a trigger.
But none of them show up, stating "no supported devices found" (see the discovery.txt response attached for reference).
In this post it is mentioned that certain devices are not yet supported.
So which devices / properties are actually supported and what are the requirements for this to work?
alexa smart homedevicesroutines
discovery.txt (3.4 KiB)
roy-1 avatar image
roy-1 answered
Hi Christian,
Thanks for posting. Currently, routines are controlled completely from the customer's side, and there is not a way to modify their behavior from the skill development side. I would recommend reaching out to Amazon Customer Service or posting in the Smart Home section of the Amazon consumer forums to see if a list of compatible devices can be made available.
