newuser-64a41272-f9be-4eda-8d84-71a5b807515c avatar image
Connecting dynamo db table with custom Alexa skill
Hi There,
I am working on custom alexa skill and i am getting errors in connecting the table in dynamodb with lambda in node js.Please help me with a reference.
alexa skills kitlambdaawsdynamodb
Robert G Schaffrath avatar image
Robert G Schaffrath answered
This is a snippet of code I wrote to retrieve a value from one of DynamoDB tables and then update the record:
const AWS = require("aws-sdk");
const AWSregion = "us-east-1";
AWS.config.update({ region: AWSregion });
const DYNAMODB_TABLE_NAME = "My Dynamo Table";
const DynamoDB = new AWS.DynamoDB();
const id = "My Id";
let params = {
    Key: {
        "id": {
            S: id
    TableName: DYNAMODB_TABLE_NAME
DynamoDB.getItem(params, (err, data) => {
    if (err) {
        console.log(err, err.stack); // an error occurred
    else {
        // I have a value in a field called "update". The retrieved data is in
        // data.Item.update.S
        const oldValue = data.Item.update.S;
        // Update the value in "update" for "id":
        const newValue = "New Data";
        params = {
            Item: {
                "id": {
                    S: id
                "update": {
                    S: newValue
        DynamoDB.putItem(params, (err, data) => {
            if (err) {
            else {
                // Update was successful
Have you granted your Lambda function access to DynamoDB by creation a role in IAM?
newuser-64a41272-f9be-4eda-8d84-71a5b807515c answered
Yes i have done that.I need the code to fetch the data which i am unable to do
Thanks a lot
newuser-6065c9b0-0bbe-4dd6-87c3-3e3aabec549b avatar image
newuser-6065c9b0-0bbe-4dd6-87c3-3e3aabec549b answered
Where is the connection between dynamodb with alexa? the code is mostly just dynamodb.
Hello and thank you for your message.
As @Aardvark mentioned on their reply, this is just as snippet. You need to add it to your already working skill endpoint in order to have it connect to Alexa.
Regards,
Barry
