Alexander Martin avatar image
Alexander Martin asked
APL Pager issue (navigation none can be moved)
as I already mentioned 3 months ago, it is possible to move a Pager with navigation "none".
original post + video.
https://forums.developer.amazon.com/questions/186199/bug-pager-with-navigation-none-can-be-moved.html
alexa skills kitalexaapl
Arun@Amazon avatar image
Arun@Amazon answered
Hi @Alexander Martin
We put out an update on 12/27 which seems to have fixed this issue. I purposely used a Pager with frames that cover the screen so I could see the slightest movement. Here's a video of what I saw:
https://imgur.com/a/giXIoa1. Below is the APL document I used for the test. If you still see the issue, please share the APL document/datasources you're seeing it with and the device serial number for the device you're seeing it on. Feel free to use our contact form (http://alexa.design/contactus) if you're not comfortable sharing this information on an open forum.
Arun
@aruntalkstech
    "type": "APL",
    "version": "1.0",
    "mainTemplate": {
        "items": [
              "type": "Pager",
              "width": "100%",
              "height": "100%",
              "navigation": "none",
              "items": [
                    "type": "Frame",
                    "backgroundColor": "red",
                    "item": {
                        "type": "Text",
                        "text": "Left"
                    "type": "Frame",
                    "backgroundColor": "green",
                    "item": {
                        "type": "Text",
                        "text": "Right"
