James Meyers avatar image
James Meyers asked
How to set lambda environmental variable using ask CLI?
How can I set a lambda environmental variable using the ask CLI? I tried setting the variables using the AWS console, but now when I run `ask deploy`, I get this error:
[Error]: Lambda update failed. Lambda ARN: arn:aws:lambda:us-east-1:608870357221:function:ask-custom-talk_stem-default
The Revision Id provided does not match the latest Revision Id. Call the GetFunction/GetAlias API to retrieve the latest Revision Id
lambdaask cli
Ron Wang avatar image
Ron Wang answered
Hi SimpleJ! Currently CLI doesn't control environmental variable when we manage Lambda resource(s). For this case, you can run "ask deploy --target lambda --force" to update the Lambda if you are certain of the Lambda change (if the change is only ENV VAR's change).
