newuser-18175917-1538-41b6-b4cd-243315834a19 avatar image
Issue Mapping Alexa Device with Group in Alexa app for smart home alexa skill
I can uniquely identify from which account the alexa smart home skill in invoked using the bearer token in the header. Now the scenario is that, i have two room(1st room is called Bedroom 1 and second room is called Bedroom 2) and have two alexa device (one for each room) namely echo dot 1 and echo dot 2. Each room has a light called "Bed Light". The Light name is same in both the room. Now during device discovery i assign the applianceId of Bed Light in Room 1 as "1" and applianceId of Bed Light in Room 2 as "2". However the friendlyName attribute of both the device are same as "Bed Light". Now after discovering the devices(says two devices discovered both having the same name) in the alexa app, i have created two group named "Bedroom 1" and "Bedroom 2". In the Bedroom 1 group i have added echo dot 1 and Bed Light. In Bedroom 2 group, i have added echo dot 2 and Bed Light. Also the preferred speaker in Bedroom 1 group is echo dot 1 and bedroom 2 is echo dot 2.
Now when i say turn on bed light from echo dot 1 it turns on the bedlight of Bedroom 1 as usual, however when i say turn on bed light from echo dot 2 it still turn on the bedlight in bedroom 1. In the log too i can see it is invoking the same appliance (identifying using the applianceId). I have tried to removing and adding combination(First and Second in the device list) of Bed Light in Bedroom 1 group and Bedroom 2 group. They are invoking only the same bed light.
Note that i cannot change the appliance friendly name.
How can i have same appliance name in two room and the appliance can be controlled by the alexa device present in that particular room only.
alexa smart homesmart homedevice discovery
hi any help guys? All i need is under single account, i should be able to control two light with same name in two different room using two different alexa echo device( i.e. each room has their own alexa device)
apeksha avatar image
apeksha answered
Hello there,
To control all the devices that are added to group just say "turn on <Group Name>" or
"turn off <Group Name>"
For example : Turn on Bedroom 1
Turn on Bedroom 2
Note: The Best possible way to control devices is to provide the unique friendly name for the endppoints.
