Sharvin Shah avatar image
Sharvin Shah asked
Client authentication failed in request for Amazon Alexa Smart Home skill
I am referring to Amazon documentation for the purpose of Customer Authentication. Currently, I am using LWA.
Steps I followed:
  1. I enabled the Send Alexa Events Permission from the Alexa developer Console in Build > Permission page.
  2. I took the grant code from the request in the cloudwatch logs which was sent when I logged in using Alexa companion app.
Example:-
     "directive": {
         "header": {
             "messageId": "Example",
             "name": "AcceptGrant",
             "namespace": "Alexa.Authorization",
             "payloadVersion": "3"
         "payload": {
            "grant": {
                "code": "Example2",
                "type": "OAuth2.AuthorizationCode"
            "grantee": {
                "token": "Example3",
                "type": "BearerToken"
  1. Permission Page under build on Alexa Developer console gave me client-Id and client-secret Which I used for making the post request to https://api.amazon.com/auth/o2/token.
Example:-
POST /auth/o2/token HTTP/l.l
 Host: api.amazon.com
 Content-Type: application/x-www-form-urlencoded;charset=UTF-8
 grant_type=authorization_code&code=&client_id=&client_secret=
I passed the code,client_id, and client_secret in the above example and made the post request to this URL https://api.amazon.com/auth/o2/token
  1. I tried using x-www-form-urlencoded;charset=UTF-8 and also JSON for the Content-Type.
I followed the step given in the above documentation and I am stuck on the error ( 401 Unauthorized ):
    "error_description": "Client authentication failed",
    "error": "invalid_client"
I tried implementing it using Python code and Postman both. Ending up with the Same above error scenario.
alexa skills kitalexaalexa smart homeamazon web services
2 comments
I am facing the same issue! Have you solved this issue? If you have solved then please help me.
Sorry for the late reply, but if you're still facing the issue please create a new post as this is a slightly older post.
-1 Like -1 ·
Jason@Amazon avatar image
Jason@Amazon answered
Using Inherit auth from parent and Content-Type with application/x-www-form-urlencoded should be enough for headers. Other than that, it's possible that the code that you grabbed has expired - try disabling and reenabling the skill with account linking to grab the new code and test with that.
