newuser-c90b2835-2550-4279-8200-b413cc8a57f0 avatar image
ASK Python SDK suggestion
I am using the python SDK for ASK and was successful in building the hello world demo.
I put the hello_world.py in to the same directory where the sdk was installed.
I have something like below
skill
---skill_env
---all the sdk packages like ask_sdk_core and so on
---hello_world.py
As there are many packages and I have decided to move my hello_world.py to a level above
skill
---skill_env
------all the packages
---hello_world.py
I have made changes to the packages import
before
from ask_sdk_core.dispatch_components import AbstractRequestHandler
After
from skill_env.ask_sdk_core.dispatch_components import AbstractRequestHandler
After making this change and deploying to AWS lambda, I get the below error
Unable to import module 'hello_world': No module named 'ask_sdk_model'
I am new to python and I am not sure what I am doing wrong. Do I have to reinstall the packages again to a different sub-directory to make it to work / any other setting updates need to be done.
I would prefer to have all the ask-sdk in one folder as I would like to have my modules in seperate folders for better seggregation
alexa skills kitsdkpython
Anand@Amazon avatar image
Anand@Amazon answered
Hello Developer,
You have to write your Hello World in a single python file named hello_world.py. In the the same folder where you have downloaded all ask libraries, use your favorite text editor or IDE to create a file named hello_world.py.
