I want to create the following layout:
An horizontal Sequence:
That each child is a "container" that contains child as well
The problem is that i'm putting my main data \ json in the "data" attribute of the main sequence
and then in the inner Sequence in his data attribute I'm putting the child array, when I'm using "${data}" from the child of the second sequence I'm referring the root element and not the child.
How can I achieve such an outcome?
I'm getting +- what I want in the auth tool but in my echo show it not working,
For example this layout I build will show only black screen in my echo show but in the auth tool it's working:
{ "type": "APL", "version": "1.0", "theme": "dark", "import": [], "resources": [], "styles": {}, "layouts": {}, "mainTemplate": { "items": [ { "type": "Sequence", "width": "100%", "height": "100%", "data": [ { "innerList": [ { "t": "1.1" }, { "t": "1.2" }, { "t": "1.3" } ] }, { "innerList": [ { "t": "2.1" }, { "t": "2.2" }, { "t": "2.3" } ] } ], "scrollDirection": "horizontal", "items": { "type": "Container", "spacing": "50px", "data": "${data.innerList}", "items": { "spacing": "100px", "type": "Text", "text": "${data.t}" } } } ] } }
And in a much more complex example (my real layout ) when referring to the "second"\"child" "${data}" I'm getting the root data and not the child.
Any though regarding this issue?
