newuser-4736c41e-2c3f-493f-a0d6-10de8022448e avatar image
I can't add a valid launch path to my application
my application is named as "Stock_Calc_0.0.zip" I fail to add a valid launch path when I wrote "Stock_Calc_0.0.zip/index.html" I also tried
"Stock_Calc_0.0/index.html",
"/Stock_Calc_0.0/index.html"
none of the above paths seems to work , as I contact "Amazon Developer support" - the don't support they just refer to the forum :( - sade that we make videos to support people solving their troubleshooting and they can't support us properly in return .. the uploaded app is for free! and is very useful to students
amazon appstoreamazon developer portaldeveloper portal
Ross@Amazon avatar image
Ross@Amazon answered
Make sure that the directory that your index.html file is in matches the launch path.
If your zip archive contains a folder named Stock_Calc_0.0 and the index.html file is in that folder, then your launch path is "Stock_Calc_0.0/index.html".
If the index.html file is not inside of any other directory, then your launch path is "index.html".
